996 Forum 1999-2005
Alignment question
Old Jan 21, 2021 | 07:42 PM
De Jeeper's Avatar
De Jeeper
Originally Posted by Argeo
He said He could go go to the original spec, but said with me lowering, see if desirable to do something different. Maybe I call H&R. I’m an accountant dammit. I’ll ask my indie, maybe he can do me a favor and let me know.
you will want the toe and castor to be the same. U can bring the camber up to 2.5*ish. Euro spec is 1*, usa spec is 0*. The higher * is better for track and worse on tire wear. Some say high speed stability suffers too. That being said i run 2.5* all the way around an i find it good up to 135mph, but i have an areokit which may help. I dont put a ton of miles a year in mine do if they wear out in 6-8k miles they will probably be aged out anyways.
U have to decide 4 yourself what u want.
Old Jan 21, 2021 | 08:23 PM
golock911's Avatar
golock911
I will have mine aligned to the stock settings when I finally get my Ohlin's on. It's a street car and I'm not going to chase anyone around. The lower stance and stiffer springs don't require a different setting to be effective. (infinite wisdom, not)
Old Jan 21, 2021 | 09:33 PM
Argeo's Avatar
Argeo
Thanks guys. I will relay the message.
