Replacing starter motor today!
You try soaking the flange area in PB blaster ?
Can you twist the starter at all? If you can get it to twist you will have broken the bond between starter & trans.
Some may not endorse this but u can slide a small piece of plywood under the back of the starter and use a prybar to rock the starter vertically. U have to break the corosion bond. U just want to be extra careful that u r not prying on the aos tube or the wiring harness.
im sure u will get it.
Received 1,166 Likes
Another idea - stick a long enough piece of 2x4 wood in there and hammer at an angle. With the two bolts out the only thing preventing it coming out is a corrosion bond between the starter and block. It will come out!
mjb2448 (08-26-2020)
He must be in the Hospital, I think he took Wildbilly32's method seriously !!!![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Yeah that's been done...
https://youtu.be/Gxm_qpKh7Jw
No twisting pb blaster did not work wedging wood nogo. Put it in gear and tried rocking back and forth to maybe loosen it. I'm giving up having it towed to indy today. I feel like a failure...
I would not feel bad. Sounds like you made good attempt. Will be interesting to see what they have to do to get it out. Please keep us informed.
Got my car back starts like a dream now. He struggled a little and it came off $217 with tax
A bargain! Must have forgot to add the Porsche tax!
