Whining 996
Any ideas what the problem is here? My 2001 996 C4 (tip) has a noticeable "whine" coming from somewhere. Does not happen under hard acceleration, or when coasting, but only when holding a normal fixed-speed/light acceleration. I notice it in 4th and 5th gear the most at about 47-50mph: That's when it is loudest.
If it is whining in 4th and I shift to 5th and don't accelerate, it keeps whining with no change. So in my mind it's not the engine since it seems to be rpm independant. So that leaves transmission, diffs, wheel bearings, etc.
Any ideas? Thanks in advance
This sounds a bit nuts, but have you tried turning off the AC to see if it changes? Mine was making a “whirring” sound, turned out to be in need of an AC recharge.
Could be the pinion gear, transmission, or a wheel bearing. When was the last time the diff oil was changed?
Edit: also check that it’s not coming from the radio speakers (alternator or bad ground), or from wind (a window or sunroof seal, a front cooling fan bearing, etc.)
I am fairly certain it is from the drivetrain. If I "flutter" the accelerator at 47mpg I can make it play a tune
I noticed today it really seems RPM-independent. In 4th gear at 2,200RPM is whines (47mph). In 3rd gear at about 3,000RPM (also at 47mph) it whines.
I am secretly hoping it is just a wheel-bearing. If it's the transmission I am guessing it is on the output shaft.
Diff-oil was changed about 1 month ago, and there was no change before or after. There was a seal on the diff that was also replaced - there was a small leak.
I am fairly certain it is from the drivetrain. If I "flutter" the accelerator at 47mpg I can make it play a tune![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Sounds like the "classic pinion bearing failure"..Part number
99630280800
Requires full trans disassembly. This job is to be done by professionals only, and specifically g96 /xx trans specialist, or the very mechanically inclined and not " faint of heart " DIY'ers...Trending Topics
How many miles on the car?
Best of luck.
Best of luck.
+1....I had these symptoms and it was pinion bearing.
Not saying it's not the problem, but the part number you referenced doesn't even apply to the tip cars.
The "Tip" is an A96 ZF trans, not a G96 Getrag..
MY A96 ZF Tip has a little "whine" at speeds, been doing it for 80K miles, just a little ring-n-pinion gear whine (not failing bearing whine)..
Yep, you're right I missed the "tip" in my analysis, so my comment doesn't apply, nor does the part number.
