2001 996 C2 Where is my ICV?
New/Old C2 owner
Have a fluctuating idle so I figured I would clean the ICV but, not finding it on this one. Expected it to be on the drivers side of the throttle body. Alas, nothing there. With the electronic throttle, does the ICV reside elsewhere?
Before you do anything else, do an e-gas calibration. Turn ignition to position 1 (not start), wait 60 seconds, do not touch or move the accelerator pedal, turn key to off. Then start like normal. Inspect your oil filler tube carefully for cracks...unhook it from the air box and move it around some to inspect. Make sure the oil filler tube cap is on tight.
I have no white smoke. Can I presume the AOS is sound?
Thanks for assistance
You can not tell anything from (appears to have good vac). U need to buy a manometer and put a fitting in the oil cap and test. U need to see the long and short term fuel, you need to see the map voltage. The car will tell u what u need to know...reading and understanding the outputs is a skill that comes with experience. Once we see what the car has to say some people on this board can help.
If u dont have the tools or the skills to do this all u r doing is wasting time and money.
