Turn Signal/Indicator Problem
Subscribe
Apr 19, 2020 | 06:23 AM
Hi hopefully I’ve used the proper US term......when I push the stalk down to signal a turn the stalk does not cancel after I’ve done the turn and I have to cancel the signal manually.
i have tried taking the indicator/signal unit apart as Jeff instructs in his video here
When I opened my unit the main spring and it’s plastic arms were not broken so I reinforced it to be safe....the sliding part that is located with the two tiny black and white pins may have been dislodged so I put them back in the correct position. I then reassembled the unit and. checked everything moved correctly before putting it back in the car.
Unfortunately this hasn’t solved the problem and the turn signal/indicators still do not cancel after a turn.
Does anyone have any more suggestions on how to fix this problem....I really can’t afford a whole new unit even if any company was still shipping these items in the UK.
So over to you experts.....
Reply 0
Apr 19, 2020 | 12:31 PM
What led up to this problem? Was it working before or did you buy the car with this problem?
Any work done around the steering column before it stopped working?
Have you tried activating the turn signal, then turn the steering wheel all the way to the opposite direction?
Reply 0
Apr 19, 2020 | 12:36 PM
I’ve had the car for nearly a year and it’s never worked so I can’t be sure what caused them to stop cancelling.
On opening the case up a tiny piece of black plastic fell out....when I say tiny I mean tiny triangular 2mm x 1mm but couldn’t see anything from where it could have broken off. The main side pieces on the indicator stalk as featured in the video were fine and the big strong spring sat evenly in the correct position.
Reply 0
Apr 19, 2020 | 12:47 PM
Ah. I think that tiny black plastic piece is your answer.
Where it goes will likely fix the problem. However, if it broke off, I highly doubt it can be reattached.
A replacement turn signal stalk might be your only solution.
Reply 0
Apr 19, 2020 | 12:54 PM
It could be so what is it?
Do you actually know what the inside of the indicator unit looks like and what the various parts do? If so please help me if not there’s really not much point commenting as it is not helping me find a solution.
Hope that doesn’t sound too harsh but I’d really like to fix this problem after spending two days fiddling with the unit
Inside Indicator unit
Another view
Reply 0
Apr 19, 2020 | 01:36 PM
I've done mine, so I know what it looks like. Can you show a picture of the stalk? I can't see it clearly. I think I am seeing the part of the stalk that goes into the module, and looks like both tabs are broken off. Those tabs are what is needed to hold the wire spring in place and allow teh stlk to snap back into off position. If they are broken off, the stalk is toast. You cant glue them back on. This type of plastic glue doesn't work so well. Crazy glue won't work.
Reply 0
Apr 19, 2020 | 01:47 PM
Thanks Jim here’s a couple of photos of the indicator stalk itself.
One side of indicator stalk
The other side with spring and side wings intact
Reply 0
Apr 19, 2020 | 01:53 PM
Here’s the slider part that located into the case slot and moves when you push stalk either way
The whole unit
Slider thing
Reply 0
Explore
Apr 19, 2020 | 02:03 PM
Ebay is your friend...🤷‍♂️
Reply 0
Apr 19, 2020 | 02:07 PM
Well the tabs are there, so its not that. The tabs are the part that always break and thatis what prevents the indicator from returning to off.
Hmm ... so if the mechanical parts are good (when you put it back together, the stalk could be set in the up down and middle position), not a mechanical problem.
If this little piece that fell out is so tiny, I doubt I can tell where it came from, but put a picture up anyway?
If its not mechanical, then has to be electrical.
Reply 0
Apr 19, 2020 | 02:10 PM
Quote: Ebay is your friend...🤷‍♂️
The Ebay units are almost always bad. I had to search long and hard for one that had a good stalk. And when I did find one and had it in my hands, I took it apart only to find that the plastic tabs were broken anyway, just hadn't fallen out of place. I had to take my good stalk and put it into the ebay module.
But that could be a solution if you can't find the problem. I still think there must be an issue with how the stalk is seated in the module. I doubt its electrical, but I can't say for sure.
Reply 0
Apr 19, 2020 | 02:14 PM
Yep agree with you Jim....Ebay is not my friend as a friend would come round and fix it for free rather than sell you another broken one.
Here’s the bit that fell out of the unit when I dismantled it sorry don’t have any Imperial rulers
Tiny broken bit
The indicators actually work so that’s why I’m reluctant to term it an electrical problem...it’s just the cancellation part that doesn’t work
Reply 0
Apr 19, 2020 | 02:25 PM
I'm in Canada, so no imperial system for me.
Yeah, have no idea where that part is from. I'm at a loss. All I can say is what you have done already. Reassemble and try moving the stalk and try moving it and see if maybe it becomes evident where that broken piece is from. I know that is hard, since it is a pain to keep all those springs in place and not have them all pop out.
If it were to be electrical, then I assume that to cancel there needs to be current through one of the brass strips (or lack of current?) that causes the spring in the the clear piece on the stalk to retract and allow the stalk to return?
Sorry I can't be more help.
Reply 0
Apr 19, 2020 | 05:54 PM
No worries I’m not sure many people have attempted to fix this problem themselves....most people have just put up with the problem or bought a brand new replacement unit.
Hopefully someone out there will have the answer and will want to share the knowledge.
Reply 0
Apr 19, 2020 | 06:08 PM
I guess I'm lucky then - I've never gotten anything that didn't work from ebay... Generally speaking, it won't wind up costing you anything - but I do get that it's a PITA...
Reply 0
