My guess is the one circled in green goes to the TB Idle Control Valve and the one circled in red goes to the Evap Purge Valve. See the ICV on the side of the TB? There is nothing attached to it and there should be.
I believe you are correct. I just went and took some pictures in the engine bay. Appears after further looking at your picture you are missing the change over valve.
Very timely post as i am currenty replacing all my vacuum rubber and tube. Autoatlanta has all the parts and the change over valve is about half of what my dealer wanted. Although the diagram isnt exactly correct on the vacuum lines for the 3.4l.
Thanks for the post. My A and B hoses came loose after my recent DIY AOS install. I was second guessing myself and thinking I installed incorrectly since they came off. Just didn’t seat them well enough I guess. This weekend project. Should take care of the p1411 and p0410 codes, hopefully.
edit: B & C hoses came loose.
This car doesn’t stop surprising me ! I bought it for $7,900 in a very bad part of Miami Florida ..and I got to say I’ve never seen a vehicle miss so many parts ! Lol surprisedly runs good ..
The vacuum reservoir is not even there Im getting some parts and re routing everything .
it’s coming along so far I’ve invested on a Rear main seal ; IMS retro , clutch , short shifter , OIL air separator, spark plug, new alternator, some suspension items etc . I’ve learn a lot more than what I did with my 2003 C4S as I’m more comfortable with messing up while working on it
