Oil Change?
#31
Get a low profile oil pan that holds 10 quarts. I jack up the left rear side so I can work underneath and remove oil drain plug while my low profile oil pan is underneath the drain plug. Then I drop it back down and let it drain for a long time. Then I jack up the left rear again and because of the design of the oil sump plate a bit more oil comes out. I leave it like that for awhile, then reinstall drain plug and fill it up.
#32
Keep the car level to drain the oil. You don't have to get every ounce out (nor can you). That being said, after the oil stopped draining I did jack one side up slowly and drained some more oil.
As a point of reference, on my 02 996, after driving the car for an extensive amount of time and letting it sit for about 10 minutes, my digital oil level read 2 bars below full. Oil on the dipstick was perhaps a bit less than 1/16" below the top mark. With your current readings on the digital indicator and dipstick you are a bit low on oil.
#33
Received 1,166 Likes
I never crawl under the car while it is on the jack! The only thing going under the car is my arm to loosen the drain plug. It is not that hard to reach. I don't even lift enough to raise the tire off the ground.
#34
can you reach the filter like that too? I don't have long arms...lol
#35
Yes, it is a longer reach but since I have a spin on filter with a filter socket it is simple enough. However, if in doubt at all, or you are nervous about reaching under the car, jack it up and use a jack stand. It can be just the left rear side that needs a lift up then slide a jack stand under the rear suspension cross member.
#37
I can't tell you how many mechanics have said never be over sensitive about adding oil to these cars. You're better off keeping it at the middle of the gauge. Never overfill these engines or hydrolock will be your consequence.
#38
