Guessing from my last thread the 1999 Is a solid car
I will look up my engine number today after
work. I’ll put it up here.
Where is it? I’ll do some google research as well.
right now he right great that’s all I can tell you.
Every Porsche made after the onset of emissions control (I can’t speak to the early cars...never owned one) has had problems. People brag about the superiority of air cooled 911’s. Bull crap. I’ve owned over 10 in the last 20 years (and still own one now). Most air cooled 911’s need head work by 100k miles. Not long after that, many need full rebuilds. Ever priced an air cooled rebuild?
Does the M96/97 engine design problems? Damn right it does. However, after 20+ years these problems are known and ways to identify and proactively mitigate or even fix them are known. If you want to buy a 996/997 it’s no different than buying any other car...research the potential problems, have a good PPI and look for a good one. There is always a chance you’ll buy a bad one. But, we usually don’t hear from those who buy a good one. We hear from those who have a failure or get a “bargain” that turns out to not be such a bargain after all.
Yeah, not sure why air-cooled comes out as superior or more desirable. They need head work and rebuilds as scheduled maintenance items. Not saying they aren't good cars, I've gotten to drive a few detailing clients of mine but they aren't bulletproof. I look at it like your car may be in good shape but plan for worst-case scenario.
Jake told me this story in 102 hands-on class and I took notes. I just looked back to see what I wrote. He told me that it's year 2000 cars to look out for, due to the fire. He said the telltale is a blue stripe on the engine block. The issue was Porsche had to go back and use engine blocks that had previously failed quality control - and they tried to fix them. The blue stripe is the old indicator that it had failed quality control. This is why those engines had unique issues to other M96's.
Also in my notes - if you guys think this is interesting - he told me if you see a magenta stripe on a M97 it means it's a rare M97 with a Mk2 M96 IMSB, not the larger M97 IMSB.
The casualty: mistakes
Using a yin and yang example:
Yin is stable, consistent, rule-abiding production of all the traits that make a 911 so great, unchanged, and if followed forever, would result in a disastrous car that is ‘perfect’ for what it is, that a select few people would buy, but terrible by modern standard, resulting in Porsche going out of business. That’s a run-on sentence. So is the next one.
Yang is ever-changing, adopting new techniques, experimentation, pushing the envelop, adhering to new regulations, changing 80% of the parts every new generation, failing, making mistakes, fixing those mistakes the following year, making the car faster, stronger, better, more technologically advanced, safer, shaving weight because it’s too heavy now, cutting some corners because it costs too damn much now, and then trying to sell it to more and more people to make a profit based on the Yin reputation from prior.
Do either one to extreme and you die. Get the balance between the two wrong, and you might just barely survive. Strike a great balance between the two, and you excel. And it’s really, really hard.
- coolant expansion tank cost $600
- Chain guides are a PITA to replace (IMS guides requies splitting the engine, thousands of $$$)
Good thing with 1999:
- From what I recall less chance of D-chunk
- IMSB is apparently more robust
- No can bus so LS swap is easier
After reading 100000 posts about this it seems like frequent oil changes is the #1 factor of engine life (somehow this affect chain guide as well). And don't put on slicks and try to reach 2g for extended period of time with stock oil cooling system.
