The "Ultimate AOS Solution"
#766
BmacIL, swap your low speed fan relays (from left to right) and see if the issue switches sides, too. You can also switch with the high speed relay.
#767
#768
There is no control unit. The DME tells both relays to engage at the ssme time. The fan resistor is probably bad. It's mounted next to the fan motor.
#769
whoops! Sorry, I forgot you had a 997.
