996 Forum 1999-2005
At a crossroads on my 1999 996 C2 Coupe
Old 12-31-2019, 01:29 AM
pdxmotorhead
pdxmotorhead's Avatar
A Tesla has roughly the same life-time carbon footprint as a HMMV.. The military one.. IF you factor in the raw material environmental impact.. Its even higher than a powerstroke F350..
I like driving them,, but if your going to do one,, do the Model 3 and ask the dealer for the "off the menu" minimum priced model.. they turn off about 30 miles of range and the auto assist features.. Or buy the BMW with range extender.. My girls loved it when I had it for a service car while mine was being worked on..
Old 12-31-2019, 01:52 AM
TexSquirrel
TexSquirrel's Avatar
Received 2,500 Likes on 1,338 Posts
Wow, if you decide to sell it for low teens WITH the original IMS bearing, I’d be VERY interested.
Old 12-31-2019, 02:17 AM
mattie_k
mattie_k's Avatar
Keep it. Drive it. Change the oil. Enjoy!
My 2 pesos. Your mileage may vary.
Old 12-31-2019, 01:54 PM
wkf94025
wkf94025's Avatar
Thanks @garrettsr5 for decoding the options for me! No surprises there other than the missing CD holder.
Kelly
Old 12-31-2019, 03:44 PM
911 carrera blue
911 carrera blue's Avatar
Originally Posted by wkf94025
debating whether to: (1) drive more or less as is; (2) perform IMS, RMC, clutch, etc., and continue to drive it for years; or (3) sell as is and buy a Tesla. if I am unlucky doesn't bother me. It becomes a roller, I take an uber home, and go buy that Tesla.
You still curious regarding how much would be if is a roller, so I'm thinking still doubting regarding keeping it, my history, I had it for 5 years, bought it with 3900 miles and put 28000 miles on those 5 years, I did
- Battery
- Water pump,
- Serpentine belt,
- Flush and replace all fluids,
- Changed window actuators all 4
- Sway bars
- IMS Direct feed oil
- Replaced starter
- Replaced hydraulic cylinder
- Replaced frunk hood struts
- Oil changed and filter every 5000 miles
- 3 sets of tires
- Engine mounts
- Spark plugs
This car was never tracked, more of a weekend toy but every time I used it for a week or two in a row something just give up and to top it off I was rear ended last year so my resolution was to sell it in October. Do I miss it? Hell yeah!!! but financially speaking plus the retail value of the 996 is not worth it.
Old 12-31-2019, 03:52 PM
Alpina68
Alpina68's Avatar
Originally Posted by GarrettSR5
That's a real beauty, original right down to the factory Becker CDR210 radio and exterior lights.
generally don't like red 996s but the fried egg headlights and amber tails are a very nice contrast! The white (silver?) inserts in the bumper are interesting.
That's probably not a white or silver insert, its more than likely just faded plastic.
Old 12-31-2019, 04:04 PM
NuttyProfessor
NuttyProfessor's Avatar
Comparing a Porsche 911 to a Tesla is like comparing a date with hot super model versus being locked in a padded room with a cheap blowup doll.
The following 3 users liked this post by NuttyProfessor:
Bash Hat (12-31-2019), Flyfishnick (01-03-2020), TechSavvySam (01-01-2020)
Old 12-31-2019, 04:23 PM
bourne29
bourne29's Avatar
Yep, my '99 996 has the same issue. Looking to do it when I take the bumper off to clean out the leaves. Pelican sells the grill plastic for ~$150; OP should add it to his to-do list
Old 12-31-2019, 04:26 PM
Astro
Astro's Avatar
I had an 82 Targa and sold it in 98. Missed it from the moment I sold it and it took me 6 more years until I got another one(my 99C2). Unless you want a newer model 911, save yourself the endless online searches and keep it.
Old 12-31-2019, 04:35 PM
Bash Hat
Bash Hat's Avatar
Both my 911s has faded black plastic windshield cowls. I used tire shine. Works like a charm. Only had to apply it once in the 2 years I owned my 99.
Old 12-31-2019, 08:12 PM
bourne29
bourne29's Avatar
I've had good luck with my cowl trim, but my lower grill plastic trim just keeps fading. I've tried a few different products with no luck. Maybe op will have better luck than I!
Old 01-01-2020, 02:36 PM
wkf94025
wkf94025's Avatar
Per several recent posts, yes, this is faded black, not silver or white.
Also, I couldn't find a good thread on this topic (amp, frunk contents, etc.,) so I'll tag the question on here: is this the amp in the frunk? Factory diagram suggests so. Curious absence of any labels/markings that would give a clue. If I am replacing the original CDR-210 with a Continental unit (per other threads), should I just leave the amp in? [EDIT: the Conti radio I am planning to install has amp built-in, and does not have line-out that could be fed to this stock amp.]
Old 01-01-2020, 03:26 PM
wkf94025
wkf94025's Avatar
Another question as I re-acquaint myself with my vehicle, and learn more about IMS, boring, etc. What is a typical range of oil pressure readings on the dash as one idles, drives, etc. I see oil pressure gauge read as low as 2 at idle (warm), and then at speed at 2,000 rpm typically reading 4 to 5 on the gauge. On any degree of acceleration, it pegs at 5. Does all that sound normal, or is the 2 at idle suggestive of a "loose" engine? Also, is there a good thread covering expected oil consumption? I'm putting on a few thousand miles a year, zero track, and curious what level of oil consumption is good/average/bad.
Old 01-01-2020, 03:52 PM
Bash Hat
Bash Hat's Avatar
Your pressure readings are good. I’m at 1.25 bar at warm idle with 0W oil. You may have a heavier weight oil.
Old 01-02-2020, 06:49 AM
xpierro
5th Gear
xpierro's Avatar
Thanks all for your quick and thoughtful responses. I wish I knew how to multi-quote, without spending all afternoon cutting and pasting, but here are some responses/clarifications:
  • #1 reason to switch to a Tesla is not performance, it's environmental conscience, esp with two younger kids (11 and 7) talking about it daily
There are cheaper way to consume less gasoline, like a small chinese electric motorbike for 4000 USD. And I think all those batteries will have to be thrown away somewhere at the end of the life of the car :s
But yeah the 996 drink gasoline like you drink water, so it's not like it HELP the environment ahaha
Quick Reply: At a crossroads on my 1999 996 C2 Coupe
