New owner chasing CEL
One suggestion - don't just clear the codes, reset the ECU/DME entirely. Disconnect the battery negative lead for about an hour. You really need to do this after replacing O2 sensors. It will return all ECU/DME settings to default. Then go for a drive so the ECU/DME can re-learn all the O2 sensor values feedback and can adjust to new 02 sensors.
Received 1,166 Likes
^^ I would second this - I had a situation where I got a CEL, subsequently did a bunch of work to address the code(s), and although everything spec'd properly the codes/CEL remained. It wasn't 'til I did a hard reset that they went away and remained away. In addition to disconnecting the battery, when you do, touch the two loose leads together for a second. Good luck.
Thanks DBJoe996!
This seems to have fixed the problem. I disconnected the battery for a few hours and now the O2 sensors are communications with the car computer. I'm seeing voltage where before it was 0.00. No CEL for the time being. The battery leads are not long enough to touch to each other so I didn't even try that part.
I love a good success story. Great to hear!
If your exhaust rattles don't discount the cat converter.I have one where the substrate came loose in cat ,the whole assy became detached from internal mount .Depending whether I accelerated or stopped the cel light would come on .Looking inside it was clear the cat was defective.
