Coolant Leak - Happy 4th of July
No - it was a Porsche factory water pump. We are not sure if it was the original pump or a replacement done in the past. The car has 75,000 miles on it, so if it was the original it would have been due. Wish I had taken a picture - the impeller was the plastic type - some of the vanes were worn smaller than the others. No sign of fracture.
Thanks!
Daryll
OK, sorry - I did misunderstand the question. No, the engine block is fine - the bore that I was referring to was the water pump casting itself. You could see where the impeller shaft bore in the pump was worn. I am certainly no pump expert, but I would say that the wear was expected end of life for a spinning part running in a casting. The wear on the impeller blades was interesting to me. I need to run by the shop tomorrow - if they have not tossed the old pump I will take a picture.
Thanks!
Daryll
Thanks!
Daryll
Here is a pic of the bore where the impeller impacts the block when the bearings fail ,it breaks the blades of the plastic impeller, and if it has the metal impeller, gouges in the block. Neither is a good scenario..
When the plastic blades break off the impeller, they go into the engine. You should find out how much of the blades are missing. There is really nothing that can be done now, but could be helpfull in diagnosing a problem down the road if the blades pieces get stuck in the wrong place.
I just had this same problem on my sons Boxster, that's when I decided to make the screens in the picture . Of course it was too late, but better late than never, and may be useful down the road,or if another pump fails.
Daryll
