Has anyone done an LS3 swap on here?
#46
Although I am not considering doing this (unless things change dramatically with my car), this thread got me curious. Between the vendors supporting it and affordable/available crate motors, I can see why someone would do this.
This one sounds like an easy plug and play: https://www.jegs.com/p/Chevrolet-Per...95009/10002/-1
#47
#48
It is a good option but its tought to get above 7k rpm without a lot of work to the heads. I did the math on building my motor and i think it will be around 13-14k including harness, computer and dry sump. All new parts. Getting to 8k prm cost money. Im shooting for a flat hp and tq curve passed 7.5k rpm and 500hp. It should be reliable as they r making these high rpm destroked motors over 800hp and they r staying together.
#49
Mike
#50
Anyone who has done this...aside form installing the engine and getting that running...what happens with all the electronics..instruments..a/c heat...etc.
What is the exhaust system .. headers? Mufflers?
I've a friend who is really good at this kind of stuff, he did a Chev Jag XJ6 for me a few years ago,...he's not working right now...he'd probably be up for a project.
#51
The other options for CANBUS cars include a k6 emerald ECU that marries the P car computer to the LS computer. You can also use an AEM complete replacement computer that takes the place of both the P car and LS computers in one unit. This might require you to swap the gauges but I'm not sure. The emerald ECU uses the factory P car gauges for these CANBUS systems IIRC. I believe AEM says this is 996T and 997T only but I believe they had something for the n/a carrera crowd too.
k6 emerald http://www.emeraldm3d.com/
AEM https://www.aemelectronics.com/produ...e-996-turbo-mt
Holley Terminator X https://www.holley.com/products/fuel.../terminator_x/
Stuttgart Muscle has a ton of tech on the hardware side but I don't really agree with the hardware he uses for the cooling system. My system will get -16 or -20 AN fittings throughout.
https://stuttgartmuscle.com/
#52
Just realized I only answered part of your questions...
A/C is simple for the early cars, it's a one wire hookup IIRC, use the GM mini pump and conversion fittings or lines. Not hard for a AC shop to do.
Power steering, lots of options. Use none if you don't feel you need it. Some people use MR2 setups and some people use the GT3 setup.
Heat is controlled the same way, just run the coolant lines through the new LS water pump and adapt the hoses.
Exhaust isn't that bad, plenty of options there too. Some people just run block hugger heads, others use factory manifolds. I designed a set of 180 degree headers for a more exotic sound. There are quite a few guys that have done crossover setups. Mufflers are easy too, get smaller ones that fit in the new space or make the originals work.
Cooling fans are usually controlled by the CANBUS computer on later cars and either computer desired on the earlier cars. Just need accurate temp readings and you'll be fine with either one.
There are people with working cruise control, AC, steering, etc. with build threads on LS1tech. One thing I would mention is that there is no need to cut an access hole above the the new LS like many do. You'll have to cut some of the lower support out under the "trunk" but that's it.
Mike Murphy (07-03-2019)
#54
All of that info is on the FB group "Swapped Porsche" but I believe it's done through a private party also. There's quite a few guys that do these swaps full time.
#55
I have an Ls2 in mine. I would personally stay away form Renegade. If I had to do it again, I would buy everything from Andrew (Stuttgart Muscle). Things like engine mount plate/mounts, gas pedal adapter and harness for the C7 pedal, clutch flywheel and trans adapter (although that I would get from Kennedy Engineering personally). Everything else is off the shelf, wire harness, headers, starter and manifold all fit. Exhaust you're left with a custom fab job no matter what. Hope that helps.
#56
I dont believe there is a benefit going one way or the other other than lead time and price (if you can find one cheaper and quicker). Otherwise, the Kennedy flywheel is huge and strange looking while the SM looks a bit more traditional (but I havent used it so no experience with it). Andrew, the guy that started SM, is a smart guy and very active with these swaps. I would trust him just as much as Kennedy. Initially, I didnt know if his Adapter cleared the sway bar, but now that we confirmed it does, I wouldn't hesitate to use it.
#57
#59
I have to agree that replacement of the heart or the car could certainly impact its soul. I like them both, both don’t blame you one bit. If it only had a Mezger engine...
#60
I don't think OP or anyone else asked about others opinions. I think we all know most P car owners are purists and don't like these swaps. This thread is dedicated to those swaps and questions about them so let's keep it that way. I think there's been plenty of arguing on that subject in a more chit chat related forum so no need to start it up here.
Coyote swapped Cayman, same car featured on Smoking Tire. Just another fun swap for the M96 P car variants to alleviate the dreaded IMS or oiling failures and high price tags of replacements that are doomed anyway.
The following 4 users liked this post by gtxracer:
