Mufflers full of coolant (not mine)
A friend picked up a roller (3.6) that is flooded with coolant. Gallons came out of the exhaust but runs fine.
Thoughts?
Thoughts?
Received 1,198 Likes
Coolant actually in the cylinders? Wow. Yes, a failed AOS could cause that, or the heat exchanger, or a cracked cylinder head. And yet, now it runs fine? Does the coolant level drop when it runs?
As of late yesterday the coolant was not topped off. Will learn more later.
Just a car guy
How would this work?
The only way coolant can get in the combustion chambers, and then into the exhaust, would be cracked bores, cracked head or compromised head gasket. And since we all know it's not the head gasket, that leaves the two other possibilities.
On the other hand, there is no proof (so far) that this is coolant. There is a chance water may have entered externally through the exhaust outlets and found its way into any open exhaust valves. Any flood events in the history of this car?
My 2cents
(I'll watch for future postings about this anomaly.)
Whatever the cause (source?) of the coolant, it will be expensive to repair.
At this point, I suspect lingering flood damage, and/or head gasket leakage.
relinuca
relinuca
Either they miss-assumed coolant instead of plain water/other liquid, or there is a serious problem (cracked cylinder/head) and they are being overly optimistic (runs fine?) ..
