Flat6 Innovations Bore Scoring Part 5
Unless injectors are 1,000 bucks each, and the job to install them is 15K in labor, they won't be more expensive than letting things go...
Driving these cars after them just being started up, is a hell of a lot different than driving them at temperature. With the cam adjustments at start up, and just started periods being fully advanced (to light off the catalytic converters along with fuel enrichment and secondary air injection), the whole story changes.
@wildbilly32 I shot a video of your 996 arrival yesterday, Its uploading now. Damn is it a classic for bore scoring.. We may need to video this reconstruction process, so people understand what it takes for us to overcome the problems of bore scoring.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Former Vendor
With yours being so classic, and you having found the issue yourself with the borescope, it may be difficult to do this in the future so conclusively.
BTW- Your pressure plate is grenaded.. When I drove the car back from the truck I noticed it right away due to the way the pedal felt.
Good thing my engine comes with a new one :-)
Former Vendor
I just sent a note to Jud concerning the clutch pedal feel and the brakes. When I parked it last Fall everything felt normal. Early winter I took it to my Indi for some diagnosis confirmation and other work. Part of his assignment was to check brakes and flush the fluid including the clutch system. Other than driving home a couple of miles on snowy roads I have only driven the car twice since serviced. Once to a PCA function about five miles distant and to the truck for shipping to you. Both times I noticed the hinky clutch pedal and the brakes felt different. I wrote that off to having been driving my new 2019 Civic Type R as it feels very different than the Porsche or that the Indi did something wrong. I'm glad you know what that is and will fix it during the rebuild process. I know, once again, I made the RIGHT decision.
I think in my e46 M3 the manual says get in the car and drive and keep it under 3k until it warms up. They also had a cool feature in the RPM counter that would light up as the car warmed up and once all the lights were on it was at operating temperature. I thought that was interesting because for whatever reason not until the last 5 or so years of owning cars have I heard that you shouldn't just let it idle. Maybe its been a shift in the type of cars I have owned.
Former Vendor
Prolonged idling has always been bad for a car (any car) and I avoid it. I believe my ‘84 Carrera owner’s manual says to start the car and drive off, don’t warm it up.
“The storage oil is not a good oil to be using over the summer.”
Jake, do I need to use the same type of oil for storage as I do during the summer?
For the last two seasons I have been using DT40. I put 5000 miles over the summer on the car, change in November, and store until April 1. I do a UOA on the oil in November and then pine for my car for 4 months.
Up here in Canuckistan 8L of DT40 is $180. Using it over the winter as "storage oil" is going to add up. I am pretty sure that we (and by that I mean on this forum with Jake and/or Charles) had this discussion already, and that the result of that discussion was that for cars stored in the winter, changing before storage and not changing again in the spring was OK.
So what is better: Changing every 12 months with DT40, or every 6 months with Motul 8100 x-cess?
Former Vendor
Tracks and turrets ... the Elefant tank destroyer! Now that is an all terrain Porsche.
Former Vendor
Another excellent video. Thanks Jake for your support of this community. I was surprised that there was no discussion of temperature in the video. I thought there was a general consensus that higher oil temperatures could have reduced the oil film layer on the troublesome cylinders, with contribution to the bore scoring phenomenon. I believed this was the primary reason that the lower temperature thermostat was recommended. The video didn’t address the coolant system at all. Is there less concern that the coolant system temperature is a contributor to bore scoring?
Again, thanks Jake for this whole series of videos.
Jim
Jim
