no turn signals
no turn signals
All of a sudden my turn signals and flashers do not work. The fuse is good and the relay clicks, any ideas before I order a new relay?
Always check the obvious... like the bulbs. The green arrows work on the gauge cluster? In my experience, it was usually a simple bulb or contact issue with the wiring harness. I've rarely have had problems with the relays. When they go bad, they usually start to show signs of weird blinking and such.
As apparently this is not a common issue, I just wanted to let you know a new flasher totally fixed the problem. I'm wondering as I have LED tail lights if the extra load tends to burn out the flasher? (even though it is LED rated)
I think I will buy a spare just to keep in the glove box. I used to keep 4 or 5 relays for my 928 as they failed constantly.
