996 Forum 1999-2005
Horn Replacement Suggestions
Old 07-08-2019, 04:02 PM
peterp
peterp's Avatar
Originally Posted by Coopduc
I installed one of these, it’s great! Easy too!
https://www.amazon.com/Stebel-116900.../dp/B00CMX20H4
Thanks for the feedback. Did you need to install a relay due to the (presumably) higher current draw of the air horns, or could you wire it directly in place of the existing horn?
Old 07-08-2019, 04:10 PM
misterted
misterted's Avatar
+1
Old 07-08-2019, 04:12 PM
jllphan
jllphan's Avatar
I would recommend including the relay. It comes with the horn IIRC, so nothing extra to buy.
Good deal, as warned it’s all you’ll ever need! Quality tone as well and befitting a pcar imo.
peterp (07-08-2019)
Old 07-08-2019, 04:51 PM
Coopduc
Coopduc's Avatar
I only used the existing Porsche relay. The one that came with the horn is redundant. I removed both existing horns ( one didn’t work), and installed in the stock location, slight modification of the included bracket was necessary to clear the bumper cover.
peterp (07-08-2019)
Old 07-08-2019, 04:53 PM
NuttyProfessor
NuttyProfessor's Avatar
Mine sounds like a rubber ducky squeak. No bass at all. Embarrassing. I stopped using it cause it doesn't alert anyone. I only get weird finger pointing and laughter.
Quick Reply: Horn Replacement Suggestions
