Cam Deviation
So I have my car at the indy still getting the IMS Solution done (04 C4S with 72K miles). The guy told me that my cam deviations were 1.7 and 2.27.
How good of an indicator is that to the total health of the engine? Of course I am excluding things like AOS & water pump (both recently replaced) / IMS & RMS (getting replaced with this work) / etc.
T...
T...
Cam deviation readings can give insight as to when there may be significant wear to the variocam tensioner pads. A shop I had perform a PPI on a prospective purchase observed some tensioner pad debris in the oil filter and used readings for cam deviation to confirm a diagnosis of significant tensioner pad wear, which led to the seller to pull the car off the market to repair the issue. I am unaware of other *common* engine health issues that cam deviation can help detect. (NB I'm not a P-car mechanic, this is just my experience.)
T...
T...
Jake Raby reiterates this at the 4 minute mark in his "ECU Interrogation" video on YouTube.
