What is this in oil filiter
Hope not ��
There is any way to flush this green seals from my engine its been two oil change still showing my oil filter
I would drop the sump.
It's easy to do and you'll likely find a bunch of it down there.
I would also check or replace the "swirl pots"(#4 Oil separator) while the sump is off.
I updated my "swirl-pots" to the 997 "oil return lines" when I added my 2qt deep sump.
This might be a good time to upgrade yours as well if you can find the correct part number.
I got mine in the LN 2qt deep sump kit:
https://lnengineering.com/products/m...51-baffle.html
