1999 Key Transmitter Question
Hoping someone knows the answer to this: I have a 1999 C2 with one working key and another non-working key (essentially a blade). I just ordered part 996-637-243-01 but I received part 996-637-243-04. Part 04 is a two button transmitter, while my current keys are 1-button.
Will my local independent be able to program the car to work with the two button transmitter? I know the second button won't do anything and I don't really care. I just want to be able to remotely unlock the car and start it. I've asked the vendor I purchased from, but I suspect answers here will be faster.
TIA
TIA
My buttons on my key do not work also.....For a replacement, is this what needs to be programmed by the dealer for $200+ dollars? There's no way to update or replace by yourself somehow?
You may just have bad buttons or dead battery. There are threads that show fixes for a non-functioning remote. I'd try those first as it couldn't hurt to try a DIY. If you need new key heads (transmitter) THEN the car has to be programmed at a dealer (or well equipped independent).
I have a 1999 and I just ordered a key from Keysinthepost.com. I'm looking for a key head and transmitter to make a second key.
The original single button key head isnt in the best condition either for what its worth.
Would anyone have any part numbers for what I need to replace the button on my existing key, and to put together the parts needed for my second key (without the blade)
https://rennlist.com/forums/996-foru...th-photos.html
![](https://imagizer.imageshack.com/v2/xq90/924/5fjQdk.jpg)
I have one working key transmitter and an extra blade--eventually I'll do what you did and order a third blade from keysinthepost.com. Now I've got to get a local indy to program the car.
I know the one-button shell is available because the previous owner of my car bought one. Unfortunately I don't know the part number for that.
if anyone needs their key head rebuilt on the 986 board member particlewave
rebuilt my 2 for 60.00$ I shipped the electronic part and had them back the same week
and they work great, they were killing the battery in one day
I bought a extra ebay head unit for 160.00 with 2 fence on the post keys 60.00$
but they were not even close Nice guys though sending me 2 more but really slow from England,
Porsche wants 75.00$ to program my new key,.
Nice to know at least it's way cheaper to get them rebuilt
I had one of my 2 keys not working, so I searched here for a fix. I took the board out, and basically re soldered it. It took about 10 minutes. I just used a fine tip and touched it to the solder spots. I did remove the battery holder (i think it was 4 spots) to reach the places under it. It was very easy, you'd be hard pressed to make a mistake. I can confirm my issue was just old solder had cracked. It can't hurt to spend $20 on a cheap soldering iron and give it a try first.
Zak
Zak
Sorry to hear your keysinthepost keys didn't work. I just ordered two recently and they both work perfectly.
The new keys have a narrower cut than my old worn out key.
I had trouble getting the correct transmitters from Sunset. They made a mistake and sent a Boxster part, then took days to respond to my question about said part. Then, after finally responding to me and sending me a return shipping label, took days to send me the correct part once I'd returned the wrong part. (Perhaps that's just how it is when ordering "discount" Porsche parts online.)
