996 Forum 1999-2005
New Key Fob and Airbag light
Old 02-19-2019 | 10:11 PM
anthonyss89's Avatar
anthonyss89
5th Gear
Default New Key Fob and Airbag light
Hello, New here, I have a 996 cab 2000, and I wanted to know if there is a system that I can do to program the key fob to work with my car. Like the Durametric or the icarsoft II.
Old 02-19-2019 | 11:37 PM
dan_189's Avatar
dan_189
Hi and welcome, some more detail is required.
Do you have a new key that you've bought? If so does the key have the key tag with the keys code on it? If it doesn't the remote cannot be programmed.
Also you cant program a key to a 996/986 you program the car to the key. Cannot be done with a Durametric but can be done with a PIWIS - however you need an IPAS code which only the OPCs have - they wont give them to you.
In summary you will need to make a trip to the dealership.
Old 02-20-2019 | 10:49 PM
anthonyss89
5th Gear
I need to program the alarm to the key, Its just i replaced the fob old one and moved the pill immbile, to the new one. Do I still need to go to the dealrship
Old 02-20-2019 | 11:20 PM
dan_189's Avatar
dan_189
The pill is for the immobiliser the fob is for the remote lock/unlock
You can change over the pills and then get the dealership to program the fob
Old 02-20-2019 | 11:27 PM
anthonyss89
5th Gear
Ah Ok, because I transffered the old pill with the board over to the new fob. Thing is the old fobed never work either to unlock the car, Only to start it and drive it. I know I keep sounding repeatative. Just trying to avoid going to the dealership and looking for a way for myself to do it.
Old 02-20-2019 | 11:45 PM
Coopduc's Avatar
Coopduc
The old fob circuit board will never work unless you or your dealer have the codes that came with the fob you are trying to program. The codes look like this white tag. There is no way to do it yourself, and without the numbers in the boxes that came with the fob even the dealer will not be able to program it.
Also, it’s not programming the fob to the car, it’s programming the car to the fob.
Old 02-20-2019 | 11:47 PM
wyovino's Avatar
wyovino
The circuit board is the culprit and is a very common issue. If you want to get the remote lock/unlock working you will have to transfer the pill to the new fob (which you have done), but keep the new circuit board. You will have to take the new fob with the old pill, new circuit board, and the ID tag that came with the new fob to the dealer to make it work with your car. It can cost hundreds of dollars, depending on the dealer.
Alternatively you can buy a new remote system and install it yourself for under $100.
https://www.bergvillfx.com/index.php...ry-system.html
anthonyss89
5th Gear
Excellent thank you so much. Yes this is what I just got and transplanted the metal key and the immbolizer from the old one. I think, Only reason Y I do not know is because its my fathers car and he is not the best with computers, So i said I would look this up for him and try to find out from some forums.
Old 02-20-2019 | 11:55 PM
anthonyss89
5th Gear
What does the dealership have that I don't have or cant buy
Old 02-21-2019 | 12:12 AM
wyovino's Avatar
wyovino
A device that costs north of $5000 and access to a proprietary database.
Old 02-21-2019 | 12:18 AM
Coopduc's Avatar
Coopduc
PIWIS software and interface cable to program the car and knowledge to do it.
The car’s computer can be programmed for 5 keys total, forever. Once programmed, those codes cannot be erased, so to add a new one, there has to be vacant “space” in order for it to be added. Every car came with 2 from the factory, so that leaves room for 3 additional keys. If somewhere along the car’s history keys were lost and replaced then it reduces the number of new keys that can be programmed. Maybe this isn’t a concern for you, but could become a problem for cars that have had many owners.
Old 02-21-2019 | 02:18 AM
dan_189's Avatar
dan_189
It's the cars individual IPAS code that's the issue and to be honest it's not an issue the unobtainability of this code is keeping your car safe.
There are independents and individuals that have the same PIWIS equipment to program the car - it's the cars code that can't be obtained.
interesting regarding the number of spots of keys only being used once I was under the impression these spots could be overwritten.
OP your best best if you want remote locking and unlocking is to purchase a key from the dealership or a reputable online vendor and have the dealership program it.
There is a guy on here that can apparently revive used keys (if they aren't dead) not sure about that though.
Quick Reply: New Key Fob and Airbag light
