How many miles on your engine with the original IMS bearing?
#32
996 market value didn’t drop because of the IMS. It dropped because of the era of the car, and the recession that hit at a critical time in the life of these cars. Compare the loss of value to other European sports cars of the era and you’ll see that the 996 fared pretty well.
#33
I'm at about 64k miles with, as far as I know, the original clutch and IMS bearing. So for now, I guess I'm rolling the dice. I was thinking about just replacing the darn thing along with the clutch and RMS when I bought the car a few months ago. Now, I'm not so sure. The mechanic that did the PPI has proactively replaced three perfectly good IMS bearings. Still, I'll probably just bite the bullet and do it this spring. I'm really undecided about doing it myself or paying to have it done. If I do it, the car will be on jack stands so I'm thinking about dropping the engine and transmission rather than just the tranny.
#34
That's what you wanna see!
#35
#36
I don't share your opinion as the other Porsche-price didn't drop the same way. If my car was one year older it will worse 60,000.00 more dollars and I personally think that this is mainly due to the bad publicity made around the IMS issue. Just take a look to what is said on youtube
#38
Question to you...
Gotta question since you worked with Porsche for a long time. When a customer towed a in-warranty 996 to your dealership for repair and you determined it was catastrophic engine failure because of the IMS bearing, how were you instructed to repair the customers car? Did Porsche have you rebuild the motor with a new intermediate shaft? Or did you just replace the motor with a Porsche remanufactured "AT" engine?
#40
#41
not really IMO. The IMSB gets all the bad publicity, but it’s not the only problem with these engines nor is it the most likely failure mode. For example, my car had an engine failure at 59k miles due to a spun con rod bearing. Also had evidence of intermix, bore scoring, and insufficient lubrication. I didn’t own the car at the time of the failure. When I took the engine apart for analysis, the IMSB was in prefect condition!
#42
#43
The 9A1 is a very recent design. No one will really know it’s weaknesses for a while. Direct injection definitely has it’s own set of issues and the significant design changes of the 9A1 will reveal it’s own set of issues with time. If I owned a business rebuilding Porsche engines I wouldn’t give away everything until I was certain I understood the problem and had a solution. That’s just good business.
I’d be real interested to know the outcome if the IMS case had reached the same judge that ruled against Ford on the TFI module. We’d all likely have free engines or seriously extended coverage.
#44
We are always learning. That never stops. Thats why we will never be experts. Experts stop learning.
#45
I asked a very simple question to Rennlisters about 996 mileage with the original IMS and see that some folks feel insulted and keep pushing to change the subject of this thread. Are some questions are forbidden by the owners of the true IMS religion?
