Is there a consensus on the best intake modification out there?
Originally posted by Ghost Rider
Best intake mod is the ORANGE CAP mod, free, and a guaranteed butt dyno of at least a gajillion hp!
At least it sounds better...
I'm glad you guys are getting nice "sound" (
) results from the orange cap, but this mod makes me a bit nervous. The main reason is because the cap is not fixed in place. The position of the cap is past the stock metal grate and plastic protection screen which are located just before the MAF sensor. Ergo, if the cap comes loose... "Hello, throttle body!"
It should make a difference in the induction sound, though, since the majority of the silencer is blocked off.
The Fabspeed kit loses the silencer increasing airbox volume just before the air filter, and the plastic "plug" screws in using two of the three stock screws which are in place to secure the silencer. Also, the supplied hose is devoid of the diverter arm which should cause less turbulence and improve inflow. Combined with the BMC filter and sport exhaust, this airbox mod has made a pretty significant difference in engine music. As a bonus, the throttle feels a little more responsive.
No ricin' here. Cheers.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
I was wondering since were talking mods here and by the way I like my hiflow evo intake-looks great and nice whirling sound at idle and high pitched whine going thru the gears which seems to work really well with the fabspeeds I have. I like to also add that is it possible to replace the cats with a resonator(without one be way too loud) and locate the o2 sensors(by the cat) on the muffler portion. Would you think it trigger the check engine lite? Regards. Mike
Dear dear me! Listen to yourselves guys, your driving Pcars here not Fords. You don't go modding it with freebie bits o' orange plastic. That's for ricers and wannabees. That plastic thing was "never" designed to fit on a Porsche engine. What happens if it melts, cracks, breaks up over time, becomes dislodged....I would hate to think what that thing would do if it got sucked into your engine as you slam the gas at 7000revs! Also, I hope you guys like your "check engine light" coming on, as there have been some posts with this problem popping up as a result of this mod.
Be serious. If you want a sound and secure modification, put your hand in your pocket. Were not talking big money here........and as I said, it ain't no Ford.
The Fabspeed cold airbox install will give you a simulated "mild" difference in exhaust sound. [I stress "mild"] For best results though you need to upgrade the Exhaust itself. Preferably both.
Fabspeed have provided a good video that shows the differences in sound with their cold air intake kit and BMC F1 filter: http://www.fabspeed.com/996 Cold Air kit.wmv
I know some of you use a K&N or Evo filter but I use the BMC F1 as it is the one Fabspeed suggest for their kit. Maybe they are matched. I Dunno.
This video shows off the Maxflow mufflers: http://www.fabspeed.com/996 maxflow muffler.wmv
This maxflow kit plus the above air kit and BMC F1 filter are what I have fitted. Incredible throttle response, deep growling exhaust which smacks of
Ferrari when you throttle it at high revs but grumbles quietly when cruising. IMHO, this is the best sound and performance increase you can get for around $1500. Fabspeed boast 10 hp increase with this setup.
If you go read this thread: https://rennlist.com/forums/showthre...hreadid=105964 you'll see what it's capable of. Courtesy of rennlister Doug H who has dyno tested this setup.
Orange cap indeed!
Orange cap indeed!
best intake mod for your car is the EVO supercharger which will produce 430 hp AT the wheels. the horsecrap intake kits like fabspeed "maybe" produce rounding error amonts of power increases.
FWIW, I would not go supercharger because my car is leased and I think my dealer would laugh if I tried to warranty a supercharger failure. Hence my factory turbo. Dealer said no problem on air kit and exhaust. They are also chip friendly, so they say.
Originally posted by fahren affair
i 2nd ghost's opinion, and the price is right too. the downside is i now have niagara's salespeople leaving me voice mails every other week.
You filled out the form with your REAL phone #??? You are braver than I !
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
The $10K price of admission is a bit prohibitive and then there's the warranty issue for new rides. Having said that, Ben, you have one sweeeet cab!
I wouldn't call the Fabspeed kit horsey poo, though. Sure, it's a hose and a couple of pieces of plastic... but it does eliminate the silencer improving the sound. I don't think the air kit alone would make that much difference in sound, but with sport mufflers, it has made a significant difference in the growl factor.
I was not concerned about quoted power gains... heck, I really don't believe the hype much anyway. The Fabspeed kit allowed me to lose the silencer with a part that screws in for security, increase airbox volume, and improve flow with a less restrictive filter all for a couple of hundred bucks. All this without having to mess with the stock airbox = Happy Dealer.
Orange cap indeed!
Orange cap indeed!
What happens if I inadvertently run into a deer crossing the road? The truth is the odds of hitting a deer where I live are probably greater than the orange cap disintegrating during the lifetime of my car and if it does, it is only plastic, if a metal piston can't smash a small piece of plastic and melt it during combustion and push it out the exhaust where it will get lodge in the catalytic convertor and vaporize due to high temps then Niagara must make one tough orange cap!
I'm happy to install the Fabspeed airbox instead. Please buy one from Fabspeed and ship it to me to install and I'll even take some pretty pictures and post them here. For now, the Orange Cap is all I can afford due to my former employer being acquired and the acquiring company deeming that many of us were duplicates and not needed. In the alternative you could hire me and with my first paycheck I'll go buy a Fabspeed intake, that is right after I pay the uncovered hospital bills for my wife's pregnancy.
I don't mean to be crass, but I don't make fun of whatever you do to your car, please don't make fun of what I do to mine or what I can or cannot afford. If push comes to shove the car is the first thing being let go, but they keep telling me the economy is getting better and companies are hiring. I'll believe it when I see it...
BTW, if my Orange Cap does cause a problem for my car (and I've never heard of the Orange Cap causing a CE light) I'll gladly let you tell me "I told you so"...
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
I'm the one who first discovered the Niagara plug - had this old plug in a drawer and it fit perfectly . Posted this " mod" probably 2 1/2 years ago. Anyway, do it for the slightly " rortier" intake sound enhancement above 4500 rpm . Eventually switched to the Fabspeed kit which eliminates the resonator box completely and improved throttle response quite a bit. Still sitting in a box in my garage , incl the BMC filter if anyone wants it.
Another thing - look at the bottom of the 996 air box after lifting off the air filter . On the lower right you will see about 40 little holes , which allows intake air directly from the hot exhaust below it. Look at your air filter- it is filthy in that same location, which means a significant amount of the intake air is hot air , despite the snorkel that connects through the lid to suck in outside air. They must be for allowing hot air for warm up emissions purpose , as far as I can figure, although the Turbo air box has no such thing. I blocked those holes with a thin sheet of ABS plastic screwed into four of those holes. Now you have true cold air intake. ( Don't worry, there is a separate drain hole for water that might go into the snorkel when washing or raining. )
