Frunk Latch Removal
Frunk Latch Removal
Hi all. Does anyone know of a DIY instruction page that describes how to get to and remove the frunk hood latch mechanism on a 03 C4S? When I pull the switch or use the remote fob to release the frunk, the latch opens, but the hood does not pop up. It did pop when I bought the car, so I know what it should be doing, but now I have to squeeze my fingers under the corners of the frunk and lift it up in order to get to the red lever to full open it. I've heard that there's a spring in there that sometimes breaks, but I want to make sure that's actually the issue before I start buying parts.
The lock assembly is held on by two bolts. Pretty straightforward thing to remove. You first disconnect the microswitch, then unbolt the lock, disconnect the main actuator cable, and then it will come out. The emergency release cable doesn't need to be removed from lock assembly. That being said, before you go through the trouble of removing it, you may want to consider lubricating the mechanism. It's probably sticking. However, if the hood is not popping up, then it could be out of alignment and/or need new springs. Porsche doesn't sell just the spring; therefore, you'll have to purchase the entire locking mechanism. I'm pretty sure you should expect to pay around $500 for it.
Received 1,093 Likes
Removal as described. There is a spring in the latch mechanism that comes off its post. I fixed mine by getting the spring back on the post, lubricated it well with white lithium grease, and it has been working now for several years.
Thanks for the info. When you remove the latch, is it difficult to get it re-installed again correctly or does it just go back in with no adjustment needed to get the hood to close correctly?
