996 Forum 1999-2005
Replacing interior Trim?
Old 09-14-2018 | 08:52 AM
  #31
Dranon's Avatar
Dranon
Originally Posted by GH996
Used Craft Customs to fix my carbon fiber steering wheel and they do great work.
Thanks for the heads up I will ask them for a quote!
Old 09-14-2018 | 09:42 PM
  #32
kms1990's Avatar
kms1990
If you guys were going to re-glue the interior wood trim parts on (ie the small piece above the nav in the below photo) what type of glue would you use?
Thanks!
https://ibb.co/eDjZa9
Old 09-15-2018 | 10:45 AM
  #33
peterp's Avatar
peterp
Thanks!
3M Trim Glue, sparingly, so it doesn't come out top/bottom/left/right edges when you put pressure on it to set up the glue
Old 09-15-2018 | 02:04 PM
  #34
kms1990's Avatar
kms1990
@ peterp nice, thanks! I just ordered some.
Question # 456:
Does anyone have any experience pulling the pin which holds the door pocket lids in place so I can swap them out? I posted an image below to help show this. Thank you
https://ibb.co/nb1fsK
Old 09-15-2018 | 02:44 PM
  #35
Dranon's Avatar
Dranon
This was not easy. After you remove the door panel you need to use a small punch with a hammer to get the pin out. Punch from outside to inside lightly just keep tapping it. If you just want to replace the fascia/covers I recommend unscrewing them right while attached to the door then screw new ones I. If I remember there are 11 toro screws
Old 09-30-2018 | 01:07 PM
  #36
kms1990's Avatar
kms1990
Hey all, on to the next project. This one seems like it might be the hardest yet. Thanks for all your help so far.
How would you go about replacing the parts in the photos below. This is the trim right on the top of the dash right underneath the windshield. I am replacing this because the original wood trim here is cracked and broken (shown in photos). I am replacing with a standard Savannah tan part which did not have the wood trim to prevent this from happening in the future. Thanks!
https://ibb.co/d5Ux8e
https://ibb.co/hPuauK
https://ibb.co/eqKm1z
https://ibb.co/emSH8e
https://ibb.co/dyvFuK
Old 09-30-2018 | 03:52 PM
  #37
HoustonCgrBkr's Avatar
HoustonCgrBkr
I need to replace that dash trim too, under the windshield The wood is gone. Just the plastic. Is it 2 pieces or one?
Old 09-30-2018 | 04:13 PM
  #38
Dranon's Avatar
Dranon
The wood pieces are laminate and can be heated and pryed off. The dash pieces as far as I know you have to remove the entire dash! I hope someone else has a different solution for you but they are held on by torx screws underneath.
https://www.renntech.org/forums/topi...removal-guide/
Old 09-30-2018 | 04:29 PM
  #39
HoustonCgrBkr
Holy cow, remove the whole dash to get the trim pieces off? On mine all of the wood pieces have been removed, what is left is what looks like the pieces the wood adheres to.
Old 09-30-2018 | 05:38 PM
  #40
Dranon's Avatar
Dranon
Yes that's true but he wants to replace those pieces that the wood adheres to! Look at the pics he provided. I would suggest to remove the wood pieces and just clean up where they were laminated to. OR you can craft replacement pieces or use stickers. MUCH easier than trying to replace those dash pieces.
Old 09-30-2018 | 07:34 PM
  #41
kms1990's Avatar
kms1990
@Dranon, yesir it looks like its going to be a huge project. Ouch! Should have done some research before buying these parts second hand.
Any cool ideas what you might put in the place of the wood trim? Maybe I could have something custom made.
Old 10-01-2018 | 12:40 AM
  #42
Mpfaff's Avatar
Mpfaff
The dash pieces “just”snap in to the main dash assembly,no screws from underneath.I took those panels out after the entire dash assembly was out of the car......so not sure if you can sneak them in
Old 10-02-2018 | 05:51 PM
  #43
kms1990's Avatar
kms1990
@Dranon replacing the door pocket lids by using the screws instead of pulling the pin was 100% the way to go. I could not get the pin out. The screw method worked excellent. Thanks!
Old 10-03-2018 | 10:32 AM
  #44
Dranon's Avatar
Dranon
Bought a few pieces off of Mpfaff's car. Nice guy if he says they just snap off and on then they do!
Quick Reply: Replacing interior Trim?
