Help identify engine noise
Hi Everyone,
Im an owner of a new to me 03 C4S with 37k miles. The car makes a slight ticking noise which I can hear at idle and it either goes away or is no longer audible after 11-1200 rpm. Could you please tell me whether this is something I should be worried about? I have looked at seemingly every thread and video on the internet regarding lifters and other noises, but I’m really not sure if some ticking is normal. IMS is newly replaced so I think that can probably be eliminated as a potential concern.
thank you in advance for the help!
Engine is not fully warmed up but warm enough to go down to a normal idle speed. The noise is the same when the engine is warm. I will add that I think my PSE has a broken mounting? Tab because I get the rattle in first gear only at around 3500 rpm. Could that be causing the issue?
Open rear lid and listen to each bank closely, if one side has a ticking sound, that's not so good from what I hear. Not sure exactly the cause. Hopefully others with more knowledge will chime in.
Oil was changed right before I picked up the car at the Porsche dealer, about 700 miles ago and oil level is right in the middle when I check at startup. I am not sure what kind they used but guessing Mobil 1 0w40. Should I use a different oil? I will post back with another video holding the camera under the engine when I have some time this weekend.
PSE is in default (loud) mode in the video. Doesn’t really seem to make a difference whether it’s open or closed.
I was over at the 997 forum reading a few threads on the "bore scoring" phenomenon which seems to be big problem with the M96 and M97 motors. Many claim it has a lot to do with cars from colder climates. Any chance you know where this C4S spent most of it's life? Raby has a different take on the subject and ironically he uses a motor out of a 996 C4S to explain that bore scoring is many times misdiagnosed as a noisey lifter. Check it out...
Car is from NJ, garage kept and dealer serviced its entire life. Given that it only has 37k miles, I assume it was primarily driven in fair weather. I may go to another oil type next change.
On the oil level, for street use I would recommend the level be at the top, not halfway.
You will get lots of different recommendations, this is one.
To avoid risks of overfilling the car with oil and to prevent damage to the AOS, it's best keep the oil level at the middle of the indicator. When a Porsche 996 is at the (BOTTOM) of the indicator, that means it's only 1 liter low on oil. At that point, it's best to add 1/2 of one quart of oil to the car.
Sorry I don't have answers for the op.
