LN magnetic oil plug failure and oil question
That's the reason we chose against a steel plug. The aluminum threads won't strip the pan out.
I'll point out the factory drain plug has the same mode of failure if you use it long enough or over-torque it repeatedly. Porsche intended the drain plug to be replaced every time you change the oil, like the original housing for the filter. That said, these failures are far and few between and we'll replace the drain plug for free, even though it's been in service for many, many years, as a courtesy.
Kudos
Received 5,388 Likes
Class move, Charles! To all the other Rennlist vendors, this is how you treat a customer.
wow !! thats good customer service. Thanks I will take you up on this offer. I had no idea that plug was a routine replacement item.
Ive the LN bearing on my car and have talked to your owner in the past on another Pcar. Keep up the good customer service.
I have replaced the magnetic drain plug with every oil change since my purchase of car 5 years ago.
It was suggested by a Porsche Dealer/Service center that I trust.
Expensive but a great product. I use one on my 996. Also don't have to worry about hex or torx - I think it uses a 17mm open end wrench or socket.
http://www.drainplugmagnets.com/porsche.php
I bought my LN mag plug in 2017. So it should be a newer model. I do 19 lbs with fresh crush washer. Seems like a small amount of force, but this thread explains why it is probably good. In addition, my drain plug has never leaked after at least 6 oil changes.
Bought mine back in 2017 as well, hasn't leaked but I've had to clean it and there has been residue.
Going to check it again to see if anything has changed.
fun question:
the oil is Rotella T6 5W-40
its dripping about 2 drops per minute with engine warm and off. rough calculation based on video is 1440 drops per 12 hours or 2 drops per minute
how much oil in in a drop ? which will answer how much oil will it leak in 12 hours ?
at what rate will it leak slower when the engine is cool ?
My plug stripped the very first time I used it. It had been torqued properly too. I did get a credit return from Pelican, and hopefully they sent it back to LN for failure analysis. I had one a few years back in my Boxster, and was quite happy with it. One for 2 I guess. The LN products are generally very good. I use the spin on filter adapter, and the bearing upgrade is going in this fall (did both on my Boxster). Back to the plug - it is very soft.
Let me just add that this thread is not an open invitation for people to email asking for new drain plugs for free because they want the new version. If you have a legit problem that isn't normal wear and tear, I'm happy to replace drain plugs, but no drain plug is a forever item. Just want to make that perfectly clear as several people have emailing thinking they are entitled to free stuff just because.
