Front tire width advice
Greetings
I've registered for my first DE event and I need to replace my front tires due to some dry rot. The rears are only a year old, so I'd prefer to replace the fronts only. BUT, I have a C4S and the previous owner put on 19" wheels from a 997.
The current setup I have is 235/35/19 on the front and 295/30/19 on the rear. This puts the rears about 1.9% larger than the fronts. When I inflate the rears higher than the front, I can start to feel the AWD system dragging. So I'd like to take this opportunity to change up the size of the front tires to get a better match.
My options are to go to :
245/35/19 and get circumference down to 0.8% variation
or
255/35/19 and get it 0.0% variation
Does anyone have an opinion or experience with either size on the front? I've seen some people say they like 245. Is 255 getting too wide? My front wheels are 8Jx19H2 ET 57
Thank you!
Charlie
or
Thank you!
Charlie
The 996 AWD system only works when the front tires are larger in circumference than the rears. This is due to the difference in the final drive ratios between the front and rear.
AFAIK, there is no 19 inch tire combination that will result in the right ratio between front and rear to engage the AWD system.
I now proclaim the heated discussion of the 996 AWD system open for business.
That being said - does anyone have experience or a strong opinion on going with 245, or even 255 on the front?
The all wheel drive system on the 996 uses a viscous coupling and you definitely won't feel a difference even with 5% difference in wheel size. That said, I'd stick with 235s in the front.
Quick bump - has anyone used 245 or even 255 in the front? Is there a reason why its a bad idea? Any impact on ride or handling characteristics?
Thanks again to everyone that has responded, I appreciate the insights.
Charlie
If I understand the AWD viscous coupling, the greater the difference in speed (RPM) between the front and rear, the more 'engaged' the front drive. The purpose of keeping the circumference of the front and rear close is to minimize overworking the viscous coupling. I typically stay within 2%. with 235-40-18 on the front and 285-35-18 (Michelin 4S) the rear is slightly less than 2% greater in circumference. Somewhere I read the limit is approximately 4%.
Lang G
Lang G
Lang G
Lang G
Cheers
Charlie
