Rev Range Help!!!
Rev Range Help!!!
Hello All,
Newby here and looking to get into my first 911 after years of drooling...
So looking at a manual 2003 CS4 with 53K miles- IMS has been addressed around 20k miles ago.
The current owner "likes fast cars" and likes to keep the RPMs at min. 3.4-4k "all the time because the car just likes it better"...
A pre-purchase inspection found a few little things incl. poss cracked coil (cylinder 1 went dead when the dealer washed the car after inspection and owner recalls a similar previous episode)...
Can anyone help me decipher these rev range numbers?
R1- 21919- 1663.8h
R1-145- 1389.2h
operating time 1665.6h
Thank You All!
R1- 21919- 1663.8h
R1-145- 1389.2h
Thank You All!
First, the second row of data I posted is supposed to be R2, not R1...
So if I am reading correctly, (and please correct me if I am totally off)... it looks like there were 145 instances of =/>7900 rpm, most recently at 1389.2 hours...
Any other thoughts?
And any guidance is appreciated since I am a total newcomer to this arena and trying not to fall into the abyss of a "money pit" 911....
Would you consider this vehicle or walk away?
Thanks again!
If you do some searching, there was a recent thread on this topic. It was on the front page of the 996 forum a few weeks ago as I recall. The numbers were for a 997 ECU which stores 6 levels of overrev. The concept is similar for the 996 ECU which stores 2 levels.
If you do the math, 145 ignitions is less than a second at 8000 rpm. Since the total duration was short and last occurred about 300 hours ago, I would not be concerned about it.
Range 1 = Ignition events between 7200 and 7900 rpm
The conventional wisdom is that you don't buy a car that has had a range 2 ignition event in the last 50-100 engine hours.
As a point of reference, I attached the resultes from the 2002 911 Targa with 120k miles that I just bought. I didn't do a PPI, but the car looks to have been babied.
- Ignitions/3 = revolutions
- # revolutions / 7200rpm rev limit = time (min) spent at the limiter
- 21909/3 = 7303revs / 7200rpm limiter = 1 minute banging the rev limiter over the last 1665 engine hours.
That's a lot of R1s for that many miles. The car has been bounced of the rev limiter as a matter of practice, not on occasion. The R2s are not good for this engine, so while it's certainly possible that nothing terrible happened that time it was over-reved (missed downshift or simply underestimating speed while downshifting), it's not a good risk/reward scenario in my amateur, unprofessional opinion.
Checked my records and I bought an 03 C2 with 71,400 miles. DME read 4297 range 1s.
It looks like you are reading it correctly - Remember that's 145 ignitions past 7900. So 145/3 = revolutions - 48, 48 divided by 7900 = minutes past the rev limiter - .006 min., So .006 times 60 equals seconds past the rev limiter .36 sec. Can't answer your last question Only you can prevent forest fires, oops sorry got carried away. Only you can decide if .36 sec past rev range 2 is bad enough to walk away. i HOPE one of the truly smart guys chimes in with their Educated opinion (and checks my math while they are at it) public math is always a terrible thing.
The overrevs would not concern me as much as how the previous owner treated it. Was he an agressive driver, but conciencious owner who took good care of the car including regular oil changes, or was he the type who did donuts to impress his equally immature friends.
to answer Splitting A's...
I think neither,
Yes, he admitted that he drives fast but didnt appear as a "donut guy". Still, it didn't look like he took good care of it. When I went to test drive, the car was not [in my opinion] even close to what I would consider in presentable condition. It was dirty and needed a good vacuuming and going over...
Also, he converted it to Rwd but didn't bother to re-install the inside fender cover [but only on one side which was odd]... I tried to look beyond the flags because the price is pretty low but in the end, decided it was not a good fit.
looking...
looking...
looking...
Good luck in the search. Patience is your friend.
I think neither,
looking...
I think neither,
looking...
