what is the center section of the ln deep sump used for?
I'm installing an LN .5 qt deep sump extension in conjunction with an X-51 pan and baffel. The pan extension and pick-up extension I get. But, what is the small center spacer? Is it used with an aftermarket baffel? Or, is it intended to be used with the OEM X-51 pan?
Thx.; you are right! At first I couldn't see what retained the baffle riser and wondered if the x51 pan was different than the m96. But after I taking a look at how it locks into the oem lip, I see now that it doesn't stack, but
rather fits securely around the perimeter of the oem casting lip.
