Solid Engine and Transmission Mounts
He has. And Charles Navarro with his same shop told me the opposite...that there is no problem with them (in reference to semi-solids). How many Boxster and 996 race cars are out there running solid mounts? A lot. I would think if it were a major issue you would hear a lot of talk about it but you don't. At all. And with that being the case w/ solids it's doubtful there is an issue w/ semi solids.
I can tell you that I have tracked my car with the Wevo semi solids and the FF transmission insert with absolutely no noticeable issues. I would think you could feel the engine pulling back the timing and limiting power if it were detecting knock and I have had no such sensation. I would also think if it detected it enough you'd get a CEL or limp mode eventually but not sure.
Ok, just because I have to every time this comes up....
You can also accomplish the same thing with a 70 durometer tube of 3M window weld. You can fill the spaces in the transmission mount with it. Then, drill a hole in the top of your engine mounts and rinse them out with rubbing alcohol. Once dry, fill them with back up with Window Weld as well. You have now accomplished the same thing for a grand total of $20. If you want to get fancy, McMaster Carr has a wider variety of "hardness" but 70 is a good middle of the road solution.
I think someone makes new inserts for the old mounts. That would be my first try if I couldn't afford new ones before resorting to experiments.
Put in the RSS engine mounts
They are awesome for the street and a quality product
Skip the function first transmission mount Inserts
They lead to a lot of noise and especially vibration
Trust me
Speaking from experience
Trust me
Originally Posted by RSSmike
Thanks for the mention and kind words. Glad to hear you like the RSS Engine Mounts.
Highest quality
Well made
I fully support it and highly recommend it
I have all your suspension bits and the engine mounts
Very happy
Good job!
Originally Posted by jandackson
This^^^is what I am going to do. Slacker, does the alcohol rinse the fluid from the mount? I’m tempted to try this on my worn mounts with a “reverse load” on them to see if I can rejuvenate them while improving the stiffness.
Originally Posted by gobs
Where can you get the best price for the WEVO semi-solids? I see Pelican has them for $198.75
Thank you
Thank you
I'll second the props for RSS. Them and Tarett are my two favorite manufacturers of aftermarket racing bits. GMG is by far, hands down, my least favorite.
