996 Forum 1999-2005
Connector -Engine Temp
Old Mar 19, 2018 | 04:29 PM
dcdrechsel's Avatar
dcdrechsel
Default Connector -Engine Temp
Does anyone know how to buy a 4 prong engine temp sensor connector for a 1999 c2 ? I am stumped ............
Dave
Old Mar 19, 2018 | 05:35 PM
dan_189's Avatar
dan_189
Do you have a pic of the connector?
Most of them are VW, Audi, BMW there is even one on my 04' C2 with a MB star on it.from memory
Old Mar 19, 2018 | 05:37 PM
DBJoe996's Avatar
DBJoe996
Do you mean the engine temperature sensor...or the actual electrical connector that I think is part of the engine wiring loom? The sensor is Part #8 here
http://www.autoatlanta.com/porsche-p...section=107-10
Old Mar 19, 2018 | 05:56 PM
dcdrechsel's Avatar
dcdrechsel
The actual connector is what I need .Yes- it is part of the engine loom but surely there has to be a way to buy it separately . I don't have a picture of the connector because it is gone .
Old Mar 19, 2018 | 06:04 PM
dan_189's Avatar
dan_189
In my experience I've found Porsche don't generally sell the connector on the loom end - unless its a repair kit.
A bit of investigation is unfortunately required unless you can get one off a salvage car as I don't think a repair kit is available for that sensor.
Old Mar 19, 2018 | 06:16 PM
dcdrechsel's Avatar
dcdrechsel
I have been investigating with zero results .So far I have not found a salvage yard that will cut up a loom .Can't say that I blame them ...............
Old Mar 19, 2018 | 06:17 PM
dan_189's Avatar
dan_189
Thought that might be the case, do you have a pic of the sensor end?
Old Mar 19, 2018 | 06:19 PM
dan_189's Avatar
dan_189
Guessing this is it:
Old Mar 19, 2018 | 06:25 PM
dan_189's Avatar
dan_189
Could it be this:
https://www.ebay.co.uk/itm/2-PIN-CON...-/263190390525
Old Mar 19, 2018 | 06:26 PM
dcdrechsel's Avatar
dcdrechsel
I don't believe that is it .It's 4 wires one of which is blue/red .If I sound a bit vague that's because my engine is long gone and a ls6 now occupies the space .From memory your picture looks like the oil level/oil temp connector.
Old Mar 19, 2018 | 06:32 PM
dcdrechsel's Avatar
dcdrechsel
The second picture isn't it either .The 1999 996 and boxster have a different sensor then the latter models which are two pin and unfortunately different resistance values .
Old Mar 19, 2018 | 07:01 PM
dan_189's Avatar
dan_189
Just re-read that you specified 4 pin not 2!
Audi plug:
https://m.ebay.com/itm/Auto-Electrical-Plug-4-Pin-IJ0973704-Audi-Volkswagen-Porsche-/192298733670?_mwBanner=1
Old Mar 19, 2018 | 08:39 PM
dcdrechsel's Avatar
dcdrechsel
thanks but that isn't it -the sensor pins are 2x2 not 4 in a row.
Old Mar 19, 2018 | 08:45 PM
dan_189's Avatar
dan_189
Possibly, i'm not entirely sure! Based on my quick research most of the 996 engine bay temp sensors appear to be two pin not four.
Do you have a pic of your sensor and its pins?
If the sensor is 2 x 2 perhaps its not the engine bay temp sensor and could be the coolant temp sensor, that is 2 x 2:
Old Mar 19, 2018 | 09:02 PM
dcdrechsel's Avatar
dcdrechsel
that is the one and it is the engine coolant temp sensor -I caused the confusion .Sorry..................the sensor is 996-606-405-01 which I just ordered .
