I've had my car up on a lift for a couple weeks working on a few projects. I noticed a small drip on the floor (size of a nickel). Appears to be coming from this bolt/plug but I'm not sure what it's going to. As a quick reference, this is looking at the "front" of the motor where the main seal to the transmission is. While the area around the main seal is dirty, I don't see any active leaks other than right at this plug. It appears to be going into some reservoir/cooler? Almost looks like there is a crush washer there as well. haven't tried to take it out or tighten it as I'm having a hard time finding any reference to it. Your help is appreciated.
Dan
That's one of the 3 hydraulic chain tensioners (I believe it's the IMS chain tensioner judging by location - but I'm not positive). Yes, there should be an aluminum crush washer between it and the case. I think it's supposed to be torqued to around 60 ft/lbs. You might want to check that it's properly torqued (check the spec as well...).
For my education, the chain tensioner "chambers" are lubricated with engine oil? I can look up in the service manual but just in case I need to remove it, I assume I need to drain the oil. I'm just curious what the purpose of having this bolt/plug is for? You can evacuate the oil in that chamber without draining the entire motor? I appreciate the responses.
Yup, timing chain tensioner. Take a closer look to make sure it isn't leaking form above and just dripping down there though.
Yikes, adding this - important that you read up on the procedure - pin/lock the crank at TDC at the crank pulley and lock the camshafts. There are special tools for this. I have the kit from LN engineering.
Drain oil, remove tensioner (ungodly large socket required), replace crush washer, reassemble and retorque. Lots of work for a $0.49 aluminum sealing ring. While you're there, might as well replace the o-ring (and if you are adventurous, soak them in heated marvel mystery oil). Maybe do it at the next oil change interval?
Sealing Ring, 27 X 32 Part #: 900-123-147-3
Timing Chain Tensioner O-Ring, (18.77 X 1.78 mm) Part #: 999-707-344-40
Double check the torque. When I put mine back in, it leaked, then I tightened it up a hair more and the leak stopped.
If you're going to remove it to replace the washer - do some research and verify whether or not its necessary to lock the cams when removing the tensioners.
When I zoom in on my picture, I'm not confident now that there is a crush washer. I thought I saw it last night when I was inspecting it but I will double check. Looking at an article on Pelican, this appears to be the tensioner for cylinders 1-3 since it has the double concentric circle markings (the IMS tensioner has 1). I can't tell from searching yet if locking the cam is required to remove this tensioner. This is a 2004 C2 by the way. Here's another photo showing the tensioner head a little clearer. Can anyone confirm if I need to lock the cam to replace?
Diagram I was referring to on Pelican showing the different tensioner markings
I believe the latest versions of the cam tensioners have different markings. There was a thread about this a while back where someone ordered a new one and thought they received the wrong part - it turned out they just changed.
The one in your picture is on the driver's side and facing down - bank 1 (cylinder 1-3) I believe. The other one, is on the passenger side and by the oil filter and if I remember correctly is horizontal.
Yes it is the tensioner on driver side and pointing down to the ground. It appears all of this is consistent that this is bank 1 tensioner. If I need to remove the tensioner to replace the crush washer, do I need to lock the cam? I have been searching for a while and I haven't found any reference that is simply removing the tensioner. All references that I have found have been part of IMSB replacement. I obviously need to get a different shop manual because I can't find much reference to this at all. Again this is the 3.6L 2004 motor.
I can neither confirm nor deny the need for cam locking. I was removing my IMSB flange when I did mine, so everything was locked down. Other than the cost of the extra green cam plug oil seal, I can't see any good reason to NOT lock it down. Well, then again, I already have to tools, and maybe you don't. I don't think there is any harm in locking the cams and crank, but I'm just a DIYer not a pro mechanic. I'd rather do that than risk any issues with cam chains slipping, losing cam timing, etc. That sounds like a more complex and involved situation that I'd like to avoid.
