996 Cabriolet rear window regulator(s) etc.
OK, so I've poured myself a bourbon and will attempt to explain my problem(s).
1. I have a 1999 Porsche 996 Cabriolet that runs fantastic, but the convertible top cylinders and rear window regulators are shot.
2. In the beginning...the first problem to occur was a leaking convertible top cylinder. I dealt with it by refilling the reservoir every month or so because the part is so bloody expensive...I guess that's my first mistake.
3. About 6 months ago, the left rear window regulator failed...so I pulled the window shut and decided to deal with it later...yet another expensive part. Since that regulator failed, I have not attempted to open the top.
4. About 2 months ago, the right rear window regulator failed...so now I'm finally going to fix all of this...myself; I consider myself a decent backyard mechanic...this doesn't look to hard.
5. So today, I decided to try to open the roof...pressed the button (like normal) and nothing happened...except I got a red flashing indicator on the convertible top open/close switch. This I assume has happened for one of two reasons or both reasons combined: 1. the rear window regulators don't work, so the top won't actuate, or 2. the oil reservoir has run out of oil because the cylinder leaks and the top won't actuate because of that (except I don't hear the pump which I normally do even if it's low).
6. My approach (if you all should agree) is to remove the left and right rear window regulators and send them out for repair (I understand that the repair shop is good). My question is, do I have to open the top to get those out...not that it matters because I have to change the cylinders anyway.
7. The reason for question 6 is that if I have to crank open the top to remove the rear window regulators, I may then have to get the system reprogramed...but if I can leave it closed, and if there's oil in the reservoir, then I can change the regulators with the top closed, then open the top to the service position and change the cylinders...
8. Is there a civilized way to access the rear window regulators without totally destroying the trim?
OK...now my bourbon is empty, I'm ready for criticism and advice. I look forward to all your reply's...Thank you in advance.
Thank you very much, I am always humbled by people who know their stuff.
Have you tried to open the top via the 'key in drivers door' positiion. Key in door lock, hold to the left (or right not sure now). One of them. Bring to 'service position' and release. Unhook the bobble wires and hold back roof with bungee chord
I am not an expert, so there's that caveat. I had the same problems at different times, but not all together. Seems you wouldn't be able to put the top down nor into service mode if your rear Windows don't roll down. So you'll need to fix those first.
People on here have done it, and it doesn't seem too difficult, but my fat *** arms couldn't maneuver inn there really, do I ended up taking it in. Wasn't cheap, but mainly cuz the regulators are expensive.
Once that's done, you can put the top into service mode like the guy above says and tackle the cylinders. You can send them into shops that'll seek you rebuilt ones and take yours as cores. Fairly straightforward you do. There's links on the web and YouTube videos on this out there.
Good luck
Good luck
Thank you.
Good luck
Good luck
I am one of the guys that changed the cylinders and rear regulators....albeit at different times.
If you look for my posts on the rear regulators, you may find a link to a place in Brooklyn, NYC that repairs them (much less than buying new). And a few instruction on how to do it.
I also replaced the cylinders with rebuilt, you may find a link in one of those posts also.......it has been a while.
Since I was having so much trouble at the same time, I bought some used cylinders and used regulators and had them rebuilt...the regulators out of Brooklyn and the cylinders somewhere out of Florida...so I now have spares if this ever happens again, or I can sell them. I didn't think to go on the Brooklyn rebuilders site for instructions...there are some instructions on Rennlist, but they refer to a special tool...I don't know what that special tool is...I haven't found it explained yet.
I'm actually in the middle of this repair myself. I've been out of town a lot so haven't been able to get it completed but I just have to reinstall the rebuild regulator.
I had mine rebuilt from a guy who advertises on Ebay from Florida. Seems like he did a good job but I won't know until I install it. Not looking forward to the process though which is why I keep putting it off!
The special tool is an allen wrench so not really all that special.
