BAT Auction:996 with Flat 6 Innovations Stage II Track Performer Engine
Former Vendor
Rennlisters,
One of our purchasers from a couple of years ago passed away just a few months after receiving his car back from us. His family decided to sell the car, and it is currently listed on Bring a Trailer for auction through a dealer local to us.
Its fitted with our 3.8 Stage II Track Performer engine, and has only seen a couple thousand miles, since completion.
It should be interesting to see what this one goes for.
Here's a link to the auction:
https://bringatrailer.com/listing/20...he-carrera-c4/
Thanks for the heads up!
Former Vendor
That's because there's no 15% rule. This is a tiptronic, the rule is more around 24%. This is based from direct comparisons from our engine dyno, to install into the car, and then onto the chassis dyno. We have performed this comparison a few hundred times at this point, between manuals, and tiptronics, between our two engine dynos, and the chassis dyno.
If this engine were fitted in a manual, it would net around 300 RWHP, even with the 100% stock ancillaries.
No owner of a tiptronic vehicle is concerned with peak power. The engine combination that we use for a tiptronic application is completely different for the tiptronic application, as there are concerns that have to be addressed that a manual does not have.
This owner didn't care about net power; he bought the engine so it would resist the failure that he had already experienced first hand. The added power was icing on the cake, and was a secondary reason for the purchase, not the primary.
Fully optimized with our intake, exhaust, X- pipe, catalytic converters, coils, and etc this one would have made an additional 21-30HP, if it follows the traits of those that have come before it.
@Bluechip:
Wow. This will actually give me something of an idea on my car now that it's had it's 3.8 transplant.... not that I'm getting rid of it.... EVER
I was thinking more like slakers old engine was a track performer III or something. I swear I read somewhere that car was putting down 350whp. Maybe I'm thinking of something else.
Former Vendor
Slakker also had a fully optimized intake, and exhaust system. The BAT car is 100% stock in those regards.
To truly judge one of these engines one must average the HP and torque over a 5,000 RPM range. People that look directly at peak output are looking at a 250RPM snapshot of the engine's performance, and they are totally missing the most important portion of the engine's power band/ output. With a tiptronic we are ONLY concerned with torque.
For street use, just compare the area under the torque curves for the best comparison of the two engines. I always consider this as more relevant, regardless of the trans used.
Former Vendor
Thats true.. But only applicable if the engine combination wasn't also altered to optimize the operation, and gearing of the tiptronic. In this case, thats the case.
This engine is still fitted with 100% stock exhaust, stock catalytic converters, and stock throttle body. It was not fully optimized at completion, as the owner planned to add the other items before he started tracking the car.
@Bluechip:
Actually, it won't at all. Your car isn't a tiptronic cabriolet, is it? The buyer for this car will be dramatically different than the purchaser of a manual, 6 speed coupe. It will be a complete apples to grapefruit comparison.
@Bluechip:
That being said, what could a potential buyer expect if their only purpose in buying this car was to transplant the engine it into a 6 speed manual car? Would it be noticeably different from a similar engine built for a 6mt?
The problem here is that there is no "before" and "after", and I would be after a metric-crap-tonne of mid range torque.
If FSI's number of 24% for the slushbox, then peak torque is ~330 at the crank...somewhere around 4500rpm (maybe? so hard to say with that chart), which is actually pretty good. Compare a 991 3.8 makes 325 at 5600 rpm.
I think the 997S was a 355ho motor. Not sure about the new 991 but I’d bet it’s more.
The 991 base is 345hp and the S is 395. The .2 cars are 365 and 414 respectively.
