IMS Shaft Runout.... How much is acceptable?
Sure...
Those were Mr. Raby's posts a few years ago. He's assembled a team to handle the parts of this business that he doesn't care for, and he is having fun staying away from forums, and out of the office completely.
Glad to see that you have someone local to handle this for you. Remember, we only build complete engines, and don't perform any machine work :-)
Typically anything more than .005" we will fail for use with ball or roller bearings. The IMS Solution was tested and had no problems with runout of up to .015".
Also, you can't just throw the ims into a 3 or 4 jaw chuck and expect accurate results. We have soft jaws that grab the ims tube (to prevent damage to the IMS tube) and the fixture is dialed in every time before any measuring or machining operations are carried out. We typically wait until we have a bunch of shafts to do at once because of the required setup time.
Thanks for all the responses, guys! Judging from the responses and the photos I've seen which Charles N, I will re-use my IMS shaft. Plus, my engine made it 90k miles without and IMSB failure, so I think that'll be fine... Feeling much better about it now.
Former Vendor
Thanks for your sharing of the much needed detail specifications on the IMS runnout. What other machining operations of the IMS shaft do you perform on the shaft other than measuring and pinning? I know you use to offer machining of the housing to accept the 52mm bearing of the 997.1 into the 47mm bearing housings, but since the widespread use of the roller bearing and plain bearing this is obsolete.
For the record, the 06-08 shafts are the best of all the intermediate shafts and typically have zero runout.
