Key won't turn in ignition switch...
You bet! It's a ways off in July. Here in Indy the weather got cold just around Christmas AND it will be in the 50's the next two days!.....so the Winter ain't bad. No pcar projects going on but I bought a '65 Spitfire a couple months ago and that has me buying up parts
Wow Pete going over to the British side. Does your Spitfire have twin SU carbs like my 1960 Bugeye Sprite? I owned my Sprite for almost 30 years before I sold it. Best of luck with your new project..
You are a glutton for punishment Pete.
Yes and Yes. The prince of darkness decided to turn the headlights off on the way home from dinner one dark Friday night...still haven't figured it out. 2 owners that I'm aware of.
In this thread a derailment is fine. Hope to get my wood stove producing a little extra heat so I can work on my Porsche sometime today and replace the ignition switch. Thanks for the replies.
Whitlockitup (06-27-2021)
Frozen 2003 Porsche Boxster 986 Ignition Switch
Can anyone pleae help me. A dumb SOB previous owner put lock tight on the screws holding the 2003 Porsche Boxster Ignition Switch. It is hard to get into it in the first place, but to use lock tight is undescribale! Is there anyway to get it out as I need to replace it. The only thing that I can think of is taking a Dremel rotation saw and cut it out but that will take time. Any suggestions please. I have even tried brake fluid on a Q-Tip to no avail. I do not want to use a small torch flame as that might cause more harm than it is worth. kojac@triad.rr.com
@Kojac , Off the top of my head; Have you tried a heat gun or hair dryer instead of a torch? If it's blue loctite instead of red that might work. I think red requires more heat.
Could you fit a handheld impact driver in there?
You might try the tip of a soldering iron against the screw to heat it up.
cracked the steering wheel and turned immediately….. I know that… I do that all the time. Brain freeze.
The following 2 users liked this post by professorman:
Elumere (06-08-2021),
Mike Murphy (06-07-2021)
