Magnetic Oil Plug Washer Blunder
#31
#34
I have changed my oil twice since I bought the car in April, once after I drove it the 3,000 miles home, and once since then. The PO installed a magnetic oil plug that I did not know about. Both times I have changed the oil, I have had to tighten the oil plug way past where I am comfortable with it in order for it not to leak. The first time I changed the oil, I tightened it to where I usually tighten oil plugs and it didn't leak until the car warmed up. That was fun, finding an oil puddle in the restaurant parking lot. I have used crush rings both times, although I am kind of guessing which one to use because I don't know which plug this is, although its probably LN Engineering. In any case, I don't think the crush ring is the issue.
Given all this, is it time for a new pan? They look relatively cheap on pelican. Any other advice? How hard is it to change the pan? I would buy another magnetic plug, as I think its a good idea, I just won't torque it to hell.
Sorry to derail! Nice save on swapping the plugs. The second time I changed my oil, I added too much oil (don't ask). I tried to let a little oil out and re-plug, but no dice. I ended up having to buy all new oil.
#41
A long time ago I worked at a quick lube place. My claim to fame is that I once changed the oil on 150 (the pit work) in one day.
Anyway, we had a trick for when we needed to pull the drain plug after the new oil was back in the car.
Step 1: Remove Oil Fill Cap
Step 2: Put shop towel over oil fill location.
Step 3: Grab the shop vac (yes, the same one used to vacuum out the cars)
Step 4: Apply running shop vac to the oil fill location
Step 5: Remove and replace drain plug
The vacuum actually did a really good job of holding the oil in.
#42
