over size 3.2 986 boxster thrust bearings can you get them ?
Porsche Boxster 3.2 s
2001
986.
slight damage to crank shaft due to thrust spun out. asking if i can get any where over size thrust bearings.
some one did say that they are available but would like to ask if anyone would know where from or a source to contact.
Is there no one out there that can tell me any info on Thrust bearings for 3.2 Porsche Boxster. 2001.
or am i being a bit to technical on my post.
I have one big end that needs over size bearing which is no problem but to much wear on crank to Thrust bearing which is why i am asking if any one knows where or if oversize Thrusts bearings are aviable.
2001
986.
Hi yes made my own up in the end 0.05mm and the engine is running all finished
could not find any one to supply or make.
So I am in the mechanical trade offshore
made one up to save the crank shaft.
��yes made one up my self. All finished and engine complete
I am a mechanical engineer
I made up one over size to save the crank shaft
https://rennlist.com/forums/boxster-...-986-forum-67/
Gregg, you will probably have better luck getting a reply over at the BOXSTER forum:
Non exist. Your best bet is finding a used crank and carrier assembly out of a 2.7 or 3.2. We keep them in stock. Likewise cutting factory cranks for available repair bearings requires the crankshafts to be heat treatened and straightened, and that that point, I'd rather trust a crank that hasn't suffered through a failure.
Thanks for the info Charles. I don't know yet how bad my crank is. I have not dug deep enough. Another question, is it possible to see the thrust bearing without splitting the engine? I have the engine on the bench and I am just about to pull the right cylinder head for another issue. I do have a borescope available.
Gregg
Gregg
Former Vendor
Gregg
Gregg
I wish I had a list of parts that could be swapped between M96 versions.
Former Vendor
The interchange is the biggest mystery with these engines. It remauns an unexact science, but l have momorized most of what will, and will not cross over from experience. This interchange could end up as a manual someday, bit won’t be included in the M96 Definitive Guide. A few more years of experience sould be helpful to help expose us to everything, and every instance. 15 years currently isn’t enough to be absolute.
I suspected as much. Was hoping there might be some little trick to get at it. Oh well, going deep!
Once again, I appreciate your help!!!
Good thing it looks good, this is going to be a bit of work.
Hi Strudds,
I am impressed that you made your own! I am still dismantling my engine to see how bad the thrust bearing/crank is. If needed I may contact you again for advice on this. Glad you found a way to solve the problem. Did you have much material removed from the crank?
thanks, Gregg
thanks, Gregg
Thrust bearing
Hi Strudds,
thanks, Gregg
thanks, Gregg
I had just 0.05 thou taken off the flywheel side of the crank shaft thrust face.
So only needed to make up one oversize thrust bearing.
Depending on the damage to the running face on the crank shaft if this is not to bad then the crank can be saved and thrust bearings made to suit on the amount machined off.
So it is possible to repair and make a big saving on carrying out the job.
Keep in touch.
Regards
Mark
