Low beam headlight failed
I decided to go back and start at the beginning after the new HL switch was installed. Upon checking the fuses again found that that a couple were blown. That fixed the side marker issue. I then rechecked the headlight bulb and it was blown too. Put bulb from the HB in the low beam and,,,voila I had low beams again. I now have my lights back working. Proved that you have to keep reviewing you checks. I was moving in a linear fashion and did this to recheck after each step. Might have saved me from some aggravation. The ultimate failure was probably the switch but things are never easy with electrical issues.
