Question for 996 Cab Owners
What do you think about leaving the top down most of the time? Any maintenance issues that need to be addressed on the mechanism or canvas top? Should the top be cycled to maintain best operation or unfold the canvas? Any consequence to rear windows always down?
Thank you for feedback!
/exthree
2004 Carrera Cab Atlas Grey/Natural Grey
/exthree
FWIW, on my car the top is down all winter while the hardtop is installed. I don't notice any permanent creasing when I put the top up after removing the hardtop in the spring.
You have a glass rear window, so temperature shouldn't be much of a concern. With the plastic window, you have to be careful not to damage the window by lowering the top in colder weather.
You can leave the top down most of the time. I would exercise opening and closing every once in awhile. If the car is kept clean, the top doesn't accumulate dust or debris, and you don't get moisture in those folded areas, you are fine.
I leave mine up unless driving with the top down, primarily so the interior collects fewer bugs and dust bunnies. Like KoB said those with removable hard tops leave the soft tops folded down all the time. (I do not have the hard-top.)
Raggtop cleaner and 303 protectant (applied with a brush) is the only maintenance it gets, and after more than 15 years the top is nowhere close to needing replacement.
It depends when I will drive it next. The mornings are around 60 degrees now so I will have it up in the morning. The afternoons are around 80. So if the next time I drive it will be an afternoon, I leave it down. If I don’t know when the next time will be, I put it up. Complicated stuff.
I'm not sure I understand the concern. I drive with the top down in the warmer months but put it up when I park because I don't want the sun damaging the 17 year old leather interior. In the Winter, the top is down for about 6 months with the hardtop on. I help the plastic window close properly to avoid creases and place a clean microfiber cloth inside the folds when I change over to the hardtop.
I have seen no ill effects from this over the past 7 years.
I'll have to disagree here. I park mine in the garage, and if I'm in secure location (like the parking lot at work), I leave the top down and just throw a cover over the seats. So, my top stays down 90% of the time during the warm months.
