996 Forum 1999-2005
Ticking time bomb or needs oil change?
Old 09-12-2017, 09:47 AM
  #31
AWDGuy
AWDGuy's Avatar
Originally Posted by speed rII
Some of the bits looks to be aluminium shavings.
Might be a good idea to measure crank end play.
it's hard to tell but it looks like brown bits.. you could be right though
Old 09-12-2017, 10:07 AM
  #32
Tom Loder
Tom Loder's Avatar
Based on another thread and comments from Mr. Raby, I believe the materials have been identified.
circle is from the sump, rectangle is from the area outside
Aluminum shavings from manufacturing
Mystery gunk?
Timing chain guide
Old 09-12-2017, 10:14 AM
  #33
AWDGuy
AWDGuy's Avatar
Not uncommon to see.
now scope those cylinders!
Old 09-12-2017, 11:48 AM
  #34
Tom Loder
Tom Loder's Avatar
scope is being delivered tomorrow. Know of a good how to?
Old 09-12-2017, 10:18 PM
  #35
AWDGuy
AWDGuy's Avatar
I tried finding the thread where Jake explains how to get to it with a scope from underneath....no luck.
I split the cases so I haven't actually scoped from the sump
Old 09-13-2017, 12:16 AM
  #36
808Bill
808Bill's Avatar
If I'm not mistaken, he used a medical Endoscope for that one. I could be wrong though.
Old 09-13-2017, 03:55 PM
  #37
AWDGuy
AWDGuy's Avatar
Found this....jake posting in another thread...
The bore scope will usually show nothing in regard to cylinder wear. Why? Because the wear starts at the bottom of the bore. This is the point that is covered when the piston is positioned at BDC for a bore scope evaluation. The piston covers the point where wear begins, and is always the greatest.
The only way to see this is removal of the sump plate and going in from underneath, through the "back door" with the piston at TDC during inspection. This means you have to scope through the spark plug hole, and through the sump.
The issue is that you can only access 3 of 6 cylinders from the sump plate due to obstructions.
hope that helps
Old 09-13-2017, 08:12 PM
  #38
Tom Loder
Tom Loder's Avatar
Is my pan clean enough to reinstall?
Old 09-14-2017, 10:57 AM
  #39
Tom Loder
Tom Loder's Avatar
Huzzah!!!!
Oil change has greatly reduced, or eliminated the tap. Also I have not heard the "flywheel" rattle yet. Car feels awesome!
Old 09-14-2017, 02:41 PM
  #40
Porschetech3
Porschetech3's Avatar
Received 4,770 Likes on 2,151 Posts
Your flywheel could have gone from "flailing around" to "locked up". If its in the locked up mode, to verify drive in 4th gear at about 1500 rpm and see if you get any "gear noise" when lugging. (will sound like an old worn out dump truck trans). Trust that the noise didn't just go away.
Old 09-14-2017, 02:43 PM
  #41
Tom Loder
Tom Loder's Avatar
I'm betting the noise didn't go away either, unless it was something else entirely. Right now all signs are looking up.
Now to put some miles on the new Michelin PSS
Old 09-25-2017, 09:24 PM
  #42
Tom Loder
Tom Loder's Avatar
Blackstone analysis is back and looks great
https://www.dropbox.com/s/ergqfq8fg2...70911.pdf?dl=0
Quick Reply: Ticking time bomb or needs oil change?
