993 Turbo Forum 1995-1998
18inch BBS LM
Old 09-02-2016, 11:44 PM
  #31
simonheo
simonheo's Avatar
my car is pss10 and planning to ad spacer.. what width spacer should i get?
Old 09-02-2016, 11:51 PM
  #32
simonheo
simonheo's Avatar
I am ordered a 7mm spacer for the rear since i didnt want to go too aggressive..
Old 09-03-2016, 12:05 PM
  #33
Basal Skull
Basal Skull's Avatar
7mm should be fine but you can be quite a bit more aggressive than that. I had 23mm spacers in the rear as mentioned previously. 56-23=33mm offset, wouldn't go any more aggressive than that though.
Old 09-03-2016, 12:11 PM
  #34
simonheo
simonheo's Avatar
Thank you!
Old 09-05-2016, 10:04 PM
  #35
Opo
Opo's Avatar
Something doesn't look right on the rear , here's my 96 TT reverse mount and 7mm spacer on the rear ..
235 fronts
295 rears
Old 09-06-2016, 03:31 AM
  #36
simonheo
simonheo's Avatar
Thank you Opo for sharing the pictures.
I didn't reverse mount it.. will see how it looks with a 7mm spacer.
Quick Reply: 18inch BBS LM
