993 Turbo Forum 1995-1998
394mm/390 CCM Brakes!
Old 03-25-2016, 09:17 PM
RacingBrake
Former Vendor
RacingBrake's Avatar
We happened to have both Ferrari and Porsche rear CCM rotors on hand, so just took a few pictures to share with you.
350x34 is for all Ferrari rear w/o drum brake until the latest F458 which has changed to 360x32 w/drum brake
350x28 is for all pccb rear w/drum brake until the latest 991 GT3 which has changed to 390x32
We don't have 993 real rotor assembled yet but was able to run the estimated weight through computer simulation:
Another reference is the the 991 GT3 pccb replacement (ST discs) that we have been shipping:
I would say 993 rear should come in around 14 lbs in comparison to Ferrari & pccb rear @13 lbs, which the disc weight saving was penalized by the heavy stainless steel hats.
From the latest CCB rotor size in various OE set up, it can be concluded that those earlier set up was in-adequate (too small in rotor and pad), so they are prone to deterioration under the "extra" heat that a CCM rotor generates.
RB-CCM brake kits are designed based on our extensive research and knowledge and use of the latest CCM rotor technology.
Another advantage of RB CCM rotor is the iron sleeve insert for rear emergency brake (not to be confused with parking brake) - An exclusive feature developed by us for all our rear two piece rotors. Light weight aluminum hat yet retain the integrity of OE braking system.
Old 03-25-2016, 09:24 PM
RacingBrake
Former Vendor
Originally Posted by Basal Skull
Jody, I've ordered the full kit with big RB CCM rotors/hats, and RB Calipers with big pads... We will see if I actually save any weight, don't think I'm going to get 10lbs that I was hoping for on each corner but will weigh everything that comes off and goes on! Fikse's are pretty light and with the tires sizes/available I'm using which end up being slightly narrower than the largest tires I can fit on 18's, I think I will end up ahead weight wise. Then I can see if it ultimately means anything with respect to handing and track times.
Thanks for the order and the confidence you have placed on RB, and as you are waiting for the shipment we will continue updating more information so you and other members are abreast of the development.
Old 03-25-2016, 10:13 PM
Basal Skull
Basal Skull's Avatar
^ good info/weights.
What is the weight of the callipers I'm getting? thx
Old 03-25-2016, 11:42 PM
RacingBrake
Former Vendor
We are preparing the calipers (front and rear), in red, yellow, and hard anodizing finish with logo print, and should be posting them up next week in comparison with pccb and Corvette ZR1 calipers on weight.
Old 05-12-2016, 10:47 PM
Basal Skull
Originally Posted by RacingBrake
First front kit being shipped to a 993TT customer - Thank you Royjo A. for your support.
Rear kit is to follow in a few days.
https://rennlist.com/forums/showthre...ferrerid=28499
My brake kit has shipped!
Old 05-21-2016, 01:58 AM
Basal Skull
I've received the front callipers and hardware. Hats/rotors seem to be stuck in customs. Rears haven't shipped yet.
Was going to wait til more parts arrive but thought I'd post some pics for fun.
These things are huge!
Old 05-21-2016, 02:02 AM
Basal Skull
Pads look like they would be pretty easy to swap out from above - Glad as I don't think I want to have to remove the callipers each time to change pads (as in all the new cars). My home made calliper spreaders may not be big enough for these, might have to make/design a bigger set
Old 05-21-2016, 02:43 AM
PiB993
PiB993's Avatar
this will be interesting!
Old 05-21-2016, 12:02 PM
Bradford
Bradford's Avatar
Very cool!
Old 05-22-2016, 02:57 PM
Targa Tim
Targa Tim's Avatar
looking good!
no new wheels yet?
Old 05-22-2016, 11:53 PM
Basal Skull
^ was told "should not be long"...
Old 05-25-2016, 06:03 PM
993Godspeed
993Godspeed's Avatar
Going to 19s or 20s?
Wow those calipers are huge.
Old 05-26-2016, 02:25 AM
Basal Skull
^ 19" RB sent templates and CAD type files to Fikse and they say Profil (5S) series to fit...
Old 05-26-2016, 02:32 AM
Basal Skull
Got my rotors and hats today.
some comparison shots with giro disc take offs, yes these are large!
But very light. will take all my own weights of everything as parts come off and on.
Rears are supposed to ship tomorrow.
Old 05-26-2016, 03:19 AM
Mike J
Mike J's Avatar
Do these require any changes to the master cylinder or proportioning valve? Not sure if you are moving more fluid .... they sure look massive!!
Quick Reply: 394mm/390 CCM Brakes!
