Brake warning light
Brake warning light
Hello guys. has anyone found problem with brake warning light? When driving the warning light flash several times with interval from 10 to 20 seconds. Do I have to replace sensors or brake pads? If so, wich one are the best choice on pads? Any idea?
Regards
Regards
My brake pressure light stays on occasionally for an extended period upon startup...is this something to be concerned with?? The brakes have checked out ok with visual inspection as well as being driven by my shop's owner to verify.
Should I be concerned by the light though??
Thanks!!
Jeremy
Thanks!!
Jeremy
Yup, the brake booster light is normal on startup. Should go away after a little bit. Actually, it's before startup, the brake booster is electric and you can hear it when you put the key in and turn it to the first position.
The other warning lights are probably other problems.
I've melted my wear sensors at the track, causing intermittent lighting of that warning light until the sensors were replaced. Removal of the sensors with a cheap brake job may cause the same problem.
