Cam chain box cover gasket replacement with engine in car
Is it possible to replace the cam chain box gaskets with the engine in the car on a 993 Turbo?
Yes this job can be done with engine in situ, I did mine.
Most of the backend will have to come off though, including the engine carrier, AC bracket/scavenge oil pump and turbo oil return lines + loads of other stuff.
Hence mine weep, not unlike me when I found out what was involved..........
have done with engine in, and dropping the engine.
I would drop engine to do it now.
You have to remove the A/C stand, so better drop in my opinion if you have the choice
