I have a problem (and long statement)
Almost sounds like a fuel problem, like weak pump, bad filter or fuel. How old is the fuel in the car (given it was sitting for two years)? usually if it runs and then sputters and dies, its not ignition, especially if you wait and then it starts again. The fuel sat in the system for two years, that can cause all kinds of varnishing and deposits.
First step is to run a few tanks of Chevron, and and run extra Techron. You might have moisture in the bottom of the tank - have you run the tank really low?
Cheers,
Mike
Cheers,
Mike
nbenn-
I will drive through there on Thursday! I like to take the Talihina Mena route on my way to ES. I was raised in Little Rock and long for the roads you have over there in NW AR. My dad still lives in LR and is active in the PCA and Mini Club. (Boxster, Cayman S and Mini S)
You need to meet Travis who lives in Alma. Great guy and knowledgable about 993s.
I hope that we can meet sometime.
You know, I kinda keep going back to a fuel problem. It is kinda like a fuel pump going out. Or fuel or filter as was noted above. If I don't take it in to the dealer (or an indy) I am going to try changing the fuel. It may be a few days as I don't have much time right now. I will let you know what I do to get her going --- on a regular basis!
I think I will change the relay as that might be it. And should not hurt anything (except my pocket book)!
Thanks very much to all for the helpful comments.
Nathan
Nathan
nbenn-
nice garage!
There are a lot of variables we do not know - like does it happen with a full tank AND empty tank, or just one? Does it happen more if the engine is under load. Does it happen more if the car is cold? Does it happen after a longer idle time then load? Did he swap the DME relay?
BTW, there have been lots of cases of failing DME relay's that fail during driving, will allow the car to restart and be random on their failure - it's not always just an outright failure.
Cheers,
Mike
Mike good points. I was a little rushed when I posted today. I agree that it does sound more like a fuel issue or some electrical management issue.
we need more info.
we need more info.
Okay, I am back with more info!
I found the service order that I mentioned above. They changed the oil filter, 2 seal rings(?), 11 quarts Mobil 1, 6 spark plugs, fuel filter, 2 pollen air filters and filter insert. Also replaced rear tires and balanced and did alignment. Also fixed window switch and repaired air conditioning (basically recharged and found no leaks).
I picked up a relay and replaced it this evening. The car started up fine, but that is not new. I then drove the car over a mile and 1/2 and then back to the barn. The car ran fine without a hiccup one. I will risk taking it for a longer drive soon. I am cautiously optimistic that the relay solveed the problem (it cost 35 bucks). What say ye?
