White/Black/Burlwood 993; intro and questions
There was ~2-3" of air in each line, I'd guess, and given that car was so lightly driven, I think what was happening is pads were barely squeezed at all when brakes were applied. Car was probably stopping sufficiently on the rears. Hence the rust build up. After bleeding, pads are already cleaning off the rusted section. Needless to say, this is just to make the car driveable long enough to get it to the shop for brake overhaul.
How did all that air get in lines in first place? I won't know for sure until everything is apart but theory is that the pads were so corroded that they weren't retracting, and the drag against the rotor was enough to heat up and boil the fluid. All the other systems seem to be fine, but a trip to Dawe's will confirm.
You do not need a Ti alternative, just do not use impact wrenches on the nuts, they are plenty strong for their designed use. I do an initial loosen using a breaker bar, and then roll the nuts off with a small impact driver, the same goes for putting them back on. Very little impact that way, and its still quicker than totally doing it by hand. Torquing properly is important as well, 96 ft-lbs does it.
British cars: get painted colors from nature, have glossy wood trim, and get upholstered in colors with names like "biscuit."
German cars: shades of silver, with black leather and aluminum/stainless trim
Italian cars are... red, with latitude for avante garde interior color/trim
French cars... well its a null set so who cares
I'm mellowing and in any event have now had many years of fun with all-out racecars, vintage cars of all extremes, and if my most recent Porsche has an interior reminiscent of a cabin in a high end yacht, well so be it.
Yup, it's been a week since I saw these pics and even though I much prefer plain Jane black to carbon fibre or Al, I really like this wood. Maybe I'll chop down that walnut in the back yard an polish 'er up!
Turns out today was a Schattenbaum PCA track day at NJMP on the lightning circuit. My kid is home on fall break, and I just bought this nifty turbo, so we awakened at O'dark thirty, (42F) packed the tt with all the track gear it can hold (note: not much) and drove to Millville. Extracted the cup car from it's garage, begged the registrar to add two more to the black group, topped up fuel and pressures. (44 lbs rear? really?) and headed out for some cold weather lapping.
Forrest took the cup car, I set out in the new tt. First session was somewhat terrifying. I haven't driven a street car on the track in 7-8 years. I'd forgotten all about the complete absence of feedback, squishy input response, engine is silent but tires are noisy. My brakes as I described are junk so I was cautious in braking zones. Next session I took the cup car out to remind myself how to lap at speed. Next time with the tt was much better, pushing harder a lot of the vagueness goes away. At least under cornering loads. Any kind of straight line and especially the high speed curved back 'straight' were sorta spooky; the car yawing and wandering in a way no racecar would. Still i glimpsed 135 on the front straight which is mighty impressive given the conservative brake points I'd established.
Anyhow, a fun time on a beautiful day. Around 4 we figured we'd had enough fun, and drove the tt back home. We appreciated the compliant ride, powerful stereo, and cozy wood trimmed cabin! Doubt I'll track it again, it's not very satisfying in bone stock trim and I'm certainly not going to mod it. (I'll appreciate all that ground clearance when snow falls!) No fewer than three folks came up to me to wag their finger and admonish me not to track such a special car. These things are really revered by the community!
Finally got the car up to the Dawes family. Happy to see those cruddy rotors go away, this looks much better! now to rebuild/restore those calipers.
Relative to the rest of the suspension: it will be totally disassembled, bead blasted, plated/powder coated, and re-assembled with new bushings, wheel bearings, sensors, etc etc. Just too many Pennsylvania winters. It will be like new underneath.
The tt is the last of the classic Porsches, the ultimate expression of the aircooled 911, even if the body shape evolved a bit. I think it would look great with the Classic Fuchs look. Maybe it's also because one of my prior Porsches was a '78 white coupe with Fuchs. (and wild green plaid seats)
So when I found out Fuchs was back in production with 18" versions for our cars, I ordered a set from a shop in the UK (no US dealers yet I guess)
The car is still at Dawes and I don't have any tires to mount but here they are:
