Oil Filter Wrench for 993TT?
Hey All,
Need to buy an oil filter wrench to change the oil on my 993TT. Called a few venders and they didn't have a clue what size I needed.
Any reco's on a part #/SKU and where to buy it would be greatly appreciated.
Ditto on the seal washers needed for the DIY (22x27mm, 21x26mm, 11x2.5mm).
Thanks for the assist
Same as all 993's - I use this tool to get the filters off - works very well, much better than the normal socket. I have a cheap aluminum filter socket for tightening.
Cheers,
Mike
Cheers,
Mike
![](http://www.amsoil.com/StoreFront/images/g2198_300px.jpg)
Hey Mike,
Any idea what the part # is and where I can buy that?
Any idea on the specs for the socket to tighten? Can I get either at Pep Boys, NAPA, etc.?
Thanks much
Thanks much
The socket I use is a cheap one, available from the sources you mention, 74mm-76mm size. The other tool I cannot remember where I sourced it from (its been years), but its likely the same sort of place.
Cheers,
Mike
Cheers,
Mike
