how to drain maximum volume of oil
About to make the switch to V-Twin 20W-50 from Mobil1 15W-50. Still can't believe I'm going to be using the same oil in my TT as my HD SuperGlide haha but I digress....
Being the lunatic I am on matters relating to this car, I want to get as much oil out so I can get as much 20W-50 in as possible.
What is the best way to extract maximum oil during an oil change. I'm sure this had been asked before but couldn't pinpoint it on search.
My plan thus far is to drive the car till its good and warm and then immediately pull the oil tank plug, crankcase plug, some other plug in the crankcase area with a spring on it, turbo sump plugs, and both filters. Anything else I should / can drain?
I would not take out the pressure relief spring, which you are doing.
I would remove the oil feed tube to the oil pump (just below the secondary oil filter), that usually has lots.
For the turbo, I drain from:
1 - Tank when HOT
2 - Primary oil filter
3 - Sump drain
4 - Oil catch cans - each turbo
5 - Oil Feed line
6 - Secondary filter
If you want to get really wild, you can start to take out the oil cooler lines - but the idea is to dump the oil hot from the tank drain to get at least the oil out of the thermostat. The lines are much harder to drain since they go up and over in the front wheel well.
Also, when putting back the oil, I usually put in about 7-8 quarts, pull the DME, and turn over the engine until I get 1 or more Bars of oil pressure - this fills the new filters and primes the system on startup. I will then start the engine, and you can top it up when you get an accurate measure of the actual level.
For some reason, I found the last three Turbo's that I have change the oil that 9 US Quarts seems to bring the oil to the bottom of the dipstick, so how many quarts depends on where you want the level of the stick. Most people keep it 1/3 or lower in order to lessen the chance of overfill when hot, and the possible siphoning of oil into the Turbos.
Cheers,
Mike
1 - Tank when HOT
3 - Sump drain
5 - Oil Feed line
Cheers,
Mike
1 - Tank when HOT
3 - Sump drain
5 - Oil Feed line
Cheers,
Mike
1 - Tank when HOT
3 - Sump drain
5 - Oil Feed line
Cheers,
Mike
Forgot about the oil feed line. Thats the one most people remove just to get easier access to tthe small filter is it not?
I take off the oil-feed line for two reasons - one is access, but I also get a fair amount of oil from that drain.
As far as the relief spring, I suppose there is really no reason not to take it out, other than the risk of losing the spring, or putting it back wrong. I cannot remember the seal there - if its a O ring or crush washer.
Cheers,
Mike
Cheers,
Mike
Academically interesting I suppose but can't imagine it's worth all this trouble getting a pure change. I think the V Twin is marginally better and I've switched but mixed in my last 5 litres of 15w50 to use it up.
I just try to get as much as I can out in the quickest time.
